-   -   Rigid conduit installation help needed (http://www.diychatroom.com/f18/rigid-conduit-installation-help-needed-137184/)
socalsteve72 03-15-2012 09:27 PM
2 Attachment(s)
Q1-
isn't rigid conduit supposed to bottom out in hub on new service panel? I thought so, installed mine and the threads look fine but only threaded in about 8 turns then stopped. Same on the other end.
Q2-
i'm trying to figure out how to brace my service entrance rigid conduit in my garage wall to my service panel. the conduit is 1 1/2 inch and the studs are 3 1/2 (2x4) so there's no room for cross bracing behind the rmc.i was gonna brace then strap but no room(stucco exterior) any ideas??:(
Pics are attached any help is greatly appreciated-
Steve
Julius793 03-15-2012 09:39 PM
Use straps
socalsteve72 03-15-2012 10:03 PM
what should i strap to?....
i previously explained the problem, maybe i'm missing something:(
zappa 03-15-2012 10:05 PM
A1....Tapered pipe thread. It only threads in so far and becomes tight when there is no more clearance between the threads.
Julius793 03-15-2012 10:14 PM
Concrete or cinderblock what ever it is.
socalsteve72 03-15-2012 10:15 PM
I wasn't sure if it was tapered like std pipe thread, or supposed to be straight thread as i read about online.
Any ideas on strapping product(s)/ ideas on conduit supports ??
socalsteve72 03-15-2012 10:18 PM
It's stuuco on stud construction. no plywood, ony the framing to strap to.....see pics
zappa 03-15-2012 10:19 PM
Is it a code requirement to support closer to the panel than your double plate? It looks pretty secure to me. How about wooden blocking, maybe a 2x and a 1x to the closest stud and a half clamp or that thin metal strapping with the holes in it?
socalsteve72 03-15-2012 10:27 PM
Code here requires bracing every 15 inches, i agree it's secure definitely no going anywhere but don't want to get called on it
Julius793 03-15-2012 10:30 PM
We aren't understanding each other, take a 2 hole strap, drill out the stuco/concrete and use anchors. Why do you think you can only strap to wood?
oleguy74 03-15-2012 11:01 PM
more than likley gaulled threads.you should pre fit hub to conduit.don't know if it is wrong but when i pre fit hub to conduit put a little no-alox on threads.no more trbl.
socalsteve72 03-15-2012 11:10 PM
So you're saying it should bottom out in the hub?
brric 03-16-2012 05:23 AM
No, it will NOT bottom out. Just to be nosy, where is your meter?
Speedy Petey 03-16-2012 06:10 AM
I highly doubt it. It looks fine.
This is NOT correct.
IMO it is FINE the way it is.
I also ask where the meter is?
And why only 1-1/2"? Most places 2" is the minimum mast size. Is the service/feeder drop supported by the mast?
socalsteve72 03-16-2012 07:25 AM
Mast is for meter/service panel combo, min code here is 1 1/2' rigid for 200a panel i'm using 2/0 service wire
