-   -   RG6, Romex Question (http://www.diychatroom.com/f18/rg6-romex-question-10927/)
winesmile 08-22-2007 07:41 PM
RG6, Romex Question
I have a ground floor apartment and I'd like to add an additional F-Connector term on the opposite wall (where one does not currently exist) of the TV room.
A few questions:
1. The RG6 feeds come in via the crawlspace from the main property DC multi-switch to each room in the apartment. Can I add a splitter to my existing feed to the TV room and split it off to the other side of the room/wall?? I know I will not end up with two independent DirecTV F-connector terms, but at least I have the option of what side of the room to put one TV.
2. On the wall that I'm adding the F-Connector gangebox there is an existing electrical outlet near to where I'll term the connector/box. I'm lucky to have a large crawlspace to work in and I can see phone, DSS and yellow Romex runs clearly, BUT I'm not exactly sure which Romex run goes to what room, wall, etc. (or which RG6 goes where for that matter). Is there a way to trace the Romex line? Once traced can I push a RG6 up through the existing 3/4" hole in the floor joist that the Romex goes up through? I'd rather not have to drill a new hole if I don't have to....
I have more questions, but I'll leave it at that for now.
wooderson 08-22-2007 08:13 PM
A few questions:
Is there no other outlet on the same wall? Low voltage and line voltage must use seperate raceways. Also contact you property manager to see if this is approverd otherwise if you screw up its your dollar. Otherwise use wiremold if possible.
winesmile 08-22-2007 08:20 PM
I figured they needed seporate raceways - thanks for the conformation.
Got the approval.
joed 08-22-2007 08:46 PM
I don't think a regular cable splitter will work with a satellite signal. They don't pass the voltages required to run the LNB. They definitely won't work to run two sat boxes. Possible it might work for your purpose. I would do a test with some short cables before you run your permanent cables in the walls.
wooderson 08-22-2007 08:53 PM
It will work its just that you will have to watch whatever is on the other tv that is why today we run all seperate homeruns in new construction.
winesmile 08-22-2007 11:24 PM
So to be clear as I suspect if I were to split the main feed into two you would be only able to watch one program and not two independent programs (unless you run back from the multi-switch).
Can you recommend a type of splitter to test it??
joed 08-23-2007 08:02 PM
To be clear a cable splitter will work fine on the output from the satellite receiver box. Both TVs will be watching the same channel.
A cable splitter will not work to split the signal from the dish to the receiver. It definitely will not work for two receivers at the same time. I have not tried it for one receiver moved between two different locations. I can not confirm whether it will work in that case.
