Old 03-12-2013, 11:16 AM   #1
Rewiring post light
is there an illustrated sequence to rewiring my back yard post light. Am sure the underground wiring is bad. Even tho I removed the bulb it still blew a fuse.
MikeBond is offline   Reply With Quote
Old 03-12-2013, 03:32 PM   #2
Electrician
Rewiring post light
DK
Probably it's ok. Unless there was digging or rabid gophers. In the post inside the base or inside just under the fixture (bulb holder) there are wire nuts. Take these splices apart and reset the fuse. If the fuse holds, the problem's in the post light not the Underground wires.
Fuse!? I'd be much more comfortable if all the underground wires were GFCI protected. Sometimes it's required.
Glennsparky is offline   Reply With Quote
Basic light wiring question speedster1 Electrical 3 11-29-2010 07:48 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
light post jayharold General Discussion 1 06-07-2009 05:46 PM
Wiring post outlet and lamp for light post Gordon Electrical 3 09-22-2008 03:39 PM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 08:46 AM
