Rewiring Pool Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2010, 11:18 AM   #1
Rewards Points: 77
Rewiring pool pump
i wanted to rewire my pool pump because the cutoff switch outside is rusted like nuts in and out and i dont think thats to safe, and the timer is busted. it has BX cable from the panel to the cutoff switch outside and timer in the basement. i found a outdoor plastic box cutoff switch, a new timer in the basement, the rubber/plastic tubing to run the hot, neutral and insulated ground wires in, and 12/2 wire. my concern is with the breaker, its a standard 20 amp. now, isnt a GFCI breaker needed with a pool pump? i found all at lowe's. any recommendations, tips, better ideas would be appreciated.
bryan1282 is offline   Reply With Quote
Old 10-18-2010, 12:05 PM   #2
Yes it does need a GFCI breaker
If it was 240v it was not required in the past
But they changed the code
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 05:15 AM
New pool pump trips breaker?! New home owner needs advice. KenR7A Electrical 22 01-05-2011 09:42 AM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
connecting pool pump and pool sanitizer Skippy2 Electrical 5 08-17-2008 07:48 PM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 07:30 PM
