Old 06-08-2014, 05:28 PM   #1
Rewards Points: 150
Rewiring outlet
My wife informed me that when she was unplugging dehumidifier from outlet it cracked. So I said Ill replace it when I get a chance. I did so now the switch on the wall that turns on both lamps to the outlets does not turn them on and off. What did I do incorrectly? There six total wires to this outlet. 2 black 1 red 1 ground and two white. I even wrote it down but maybe put wrong wire in somewhere. all outlets in house are hung upside down with ground facing up. That being said as I unwired it the ground on top with green screw the 2 whites were plugged into the back right side the red plugged into the top back left one black into bottom left and other black onto screw outside bottom left. Now the bottom outlet runs power all the time and the top runs power when you turn on the switch on wall. where did I make a wrong turn because it wont turn on from wall but I can plug it into either outlet and light will come on doesn't matter which way the switch is off or on.
68MHJCs is offline   Reply With Quote
Old 06-08-2014, 06:33 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,002
Rewiring outlet
With the exception of your bolded statement above, I think you forgot to break the tab between the hot sides of the receptical.....
But your statements are confusing above as to what was occuring before (objective) and what is occuring now.
Are you aware of the tab that creates a split receptical.... you just bend it back and forth with needle nose pliers.
Best
Tell us
MTN REMODEL LLC is offline   Reply With Quote
Old 06-08-2014, 06:39 PM   #3
Licensed electrician
Rewards Points: 2,190
Rewiring outlet
I agree that you forgot to break the tab on the brass side. It is jumpering power around the switch.
Old 06-08-2014, 07:19 PM   #4
Rewiring outlet
Except for the OPs statement "and the top runs power when you turn on the switch on wall"
(Jim.... I guess when everything does not make sense, it concerns me some with electrical. The OP probably did not report (confused) that the top runs power in either switch position)
Best
Peter
Old 06-08-2014, 08:34 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 2,114
Rewiring outlet
Best
Peter
I think he means when everything works right.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
The Following User Says Thank You to jbfan For This Useful Post:
MTN REMODEL LLC (06-09-2014)
Old 06-08-2014, 10:04 PM   #6
Rewards Points: 150
Rewiring outlet
OK great thanks for the input! Ill do that next and let you know how everything turns out. Thanks again. I only have to break it on the brass side? And its the small 1/8" flange in between the two screws? Sounds familiar.
Old 06-09-2014, 08:37 AM   #7
Rewiring outlet
Yep.....
Old 06-09-2014, 12:42 PM   #8
Tool Geek
PaliBob's Avatar
Rewards Points: 2,024
Rewiring outlet
..... all outlets in house are hung upside down with ground ........
In the 1980's when this style receptacle was introduced the recommended orientation was for the ground pin UP.
There is no code requirement as to the ground pin orientation, Right, Left, UP or Down.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 06-09-2014, 01:06 PM   #9
Rob
Robpo's Avatar
Rewards Points: 520
Rewiring outlet
I was told that you should hang them ground up so if the metal plate falls off and something is plugged into the outlet it will be grounded. Makes sense.
Robpo is offline   Reply With Quote
Old 06-09-2014, 01:12 PM   #10
PoleCat's Avatar
Rewards Points: 598
Rewiring outlet
I don't much care if the ground pin is left or right on a horizontal mount. My OCD will not tolerate a ground pin up. Things like this make me homicidal.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 06-09-2014, 01:35 PM   #11
Rob
Robpo's Avatar
Rewards Points: 520
Rewiring outlet
l l l l l l
doesn't work
The Following User Says Thank You to Robpo For This Useful Post:
daveb1 (06-09-2014)
Old 06-09-2014, 02:39 PM   #12
Banned Electrician
HARRY304E's Avatar
Rewards Points: 162
Rewiring outlet
You mean the 1950's
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 06-09-2014, 02:46 PM   #13
Rewards Points: 186
Rewiring outlet
I agree, lol. They don't look like a face with the ground up. :0
sgip2000 is online now   Reply With Quote
Old 06-09-2014, 04:01 PM   #14
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,056
Rewiring outlet
Yes, because that obscure scenario happens daily...
The Following User Says Thank You to stickboy1375 For This Useful Post:
jbfan (06-09-2014)
Old 06-09-2014, 04:07 PM   #15
Rewiring outlet
What are metal plates??
Confusing outlet issue Penguinfan Electrical 6 03-18-2012 10:23 PM
Outdoor Outlet seansy59 Electrical 3 03-09-2012 03:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
