Rewiring Old House, Hit Brace In Outside Wall, Safe To Drill Through Bottom Plate. - Electrical - DIY Chatroom Home Improvement Forum
Old 06-29-2008, 05:27 PM   #1
Rewards Points: 150
Rewiring old house, Hit brace in outside wall, Safe to drill through Bottom Plate.
I am fishing my new wiring. I had to make some new places for boxes so I would be up to code and I had to make a few in the outside walls. I am running into a brace inside this one outside wall. I can't get past it. I spoke with an electrician friend of mine and he stated to go undereath the floor in the crawl space. He said to drill through the bottom plate. Is it safe to drill a hole in the bottom plate? I don't want to harm the structural integrity of my house in anyway and right now there is no wiring coming up from the floor or crawlspace. All wiring is through the attic. Thanks.
twilightcall is offline   Reply With Quote
Old 06-29-2008, 09:03 PM   #2
joed's Avatar
Rewards Points: 12,024
Drilling up from the basement or crawl space into a wall is very comomn pratice. No problem. Caulk the hole if you are concerned about critters etc.
Old 06-30-2008, 12:36 AM   #3
Absolutely, drilling through the bottom plate and running underneath is a great idea in your situation.
Super33 is offline   Reply With Quote
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 10:16 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 02:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 02:01 PM
