Old 09-26-2010, 12:45 PM   #1
rewiring house with plaster walls
Does anyone know an easy way to rewire a house with plaster walls without cutting into the plaster. I should be ok with second floor cause i think there is access in the attic for me to fish, but the first floor has plaster walls and ceilings and i didn't want to gut it out and redrywall if i didn't have to. thanks for the feedback
mattrussin is offline   Reply With Quote
Old 09-26-2010, 04:50 PM   #2
Mad Scientist
Does the house have a basement? I've had pretty good success getting new cable into walls for outlets from the basement. Invest in at least a 54" flexible drill bit, and definitely get the guide tool for it as well. You can guide the bit through an existing cutout where an outlet box was, and drill down through the bottom plate to fish wires. The bit even has a hole in the tip to clip a pulling grip to, so you can drill down, attach new cable to the bit, and pull it through. You'll also want to get a couple fish tapes.
Wiring through the ceilings is a bit trickier, but not too bad as long as you're running parallel to the joists, rather than perpendicular.
If you don't have a basement, things get a bit harder...
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
mattrussin (09-28-2010)
Old 09-27-2010, 01:23 AM   #3
have you considered the baseboard trim? if its big enough, and you can remove it without too much damage, you can run your new wiring right above the floor plate, behind the baseboard trim. You will still have to fish wire up to outlets, fixtures, and switches, but still less damage to the walls in the long run.
1910NE is offline   Reply With Quote
Old 09-27-2010, 08:41 AM   #4
Just call me Andrew
This link may help you install old-work boxes in your plaster walls:
http://www.hammerzone.com/archives/e...thick_wall.htm
Andrew
secutanudu is offline   Reply With Quote
Plaster walls? Is it plaster? Lots of ?s UVAjenny Carpentry 6 04-15-2009 11:19 PM
1940s house in mid TN, block walls, no insulation kscudebec Building & Construction 2 01-15-2009 05:22 PM
Rewiring Original 1952 house. TripleC Electrical 2 03-11-2008 11:11 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
