Rewiring Garage, Questions About Conduit Pros And Cons - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 05-07-2009, 07:21 PM   #31
Bigplanz's Avatar
Rewards Points: 990
Originally Posted by Scuba_Dave View Post
There you go
I'd say a car can do severe physical damage
Then no EMT in a garage either? I guess that leaves rigid threaded pipe in a single family garage?
No. You can use either ENT or EMT in a garage if it is in a location not normally subject to abuse, like the inside of a wall stud.
Bigplanz is offline   Reply With Quote
Old 05-07-2009, 07:49 PM   #32
Why use it in a stud cavity?
Waste of time & $$
Old 05-08-2009, 01:59 AM   #33
" Euro " electrician
frenchelectrican's Avatar
For moi.,
For detached garages.
I useally wired in either conduit or MC cables unless the detached garage have enclosed wall cavites then it can be either romex or MC depending on what code it get snagged.
For attached garage.,
Main circital part is make sure you have firewall { typically 3/4 drywall ( some may say 5/8 inch ) } as far for type of cable or conduit it pretty much depending on the set up however with attached garage there is no restriction of numbers of circuits run into garage not like detached garage it must have a single circuit going in there.
Merci,Marc
purple martin/bat house pros and cons? DangerMouse Pest Control 12 01-15-2009 07:25 AM
Questions for the Pros Concordseeker Flooring 7 12-11-2007 05:13 PM
Please explain the pros and cons to gutters. curls00 Roofing/Siding 1 11-14-2007 12:42 PM
