Rewiring A Garage - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2009, 11:11 PM   #1
Rewiring a garage
I'm wanting to rewire the way my garage is set up, but I need some advice.
Here's what I have right now:
All of the power for the garage goes from a 3-way switch inside the house attached to 3-wires that run from the house to the garage. These 3 wires are attached to a light and a 3-way switch in the garage.
The problem is, everything else in the garage is running from this light, so when the switch in the house is tripped, everything in the garage loses power except the light, which can still turn off and on with the other 3-way switch.
So my question is:
Is there a way I can use the existing 3 wires and have constant power to some devices, and have a single-pole switch inside the house for the light in the garage, or would I have to run one more wire? I'm wondering if I could run one hot wire, and two neutral wires, one which is going through the switch, and another that is constant.
I'm having trouble wrapping my head around it.
Any help is greatly appreciated.
Vertigo50 is offline   Reply With Quote
Old 11-16-2009, 11:15 PM   #2
You only have 3 wires in total ? Colors...black white & copper ground ?
Attached or detached garage?
Old 11-16-2009, 11:20 PM   #3
Detached garage, which is why I'm trying to use the existing 3 wires, without having to run another wire outdoors.
I'm not sure on colors, but they're hot, neutral, and traveller right now.
Old 11-16-2009, 11:42 PM   #4
No ground wire tho ?
Any upgrade/change would require you to meet todays codes
Min 4 wire run - 2 circuits could be set up on a multi-wire branch circuit
Is the wire buried in the ground or in conduit ?
Old 11-16-2009, 11:49 PM   #5
Actually, neither. They are running from under the rain gutters to the garage overhead.
Old 11-17-2009, 08:05 AM   #6
Do you have a pic of the wire?
There are very specific wires to use for outside
Do you know how old the wire is?
Any signs of wire insulation being damaged by sun exposure?
Without a ground you really don't have a setup that meets code
Old 11-17-2009, 10:26 AM   #7
Licensed Pro
This is an improper and dangerous setup for 3way switching called the Carter System. You can use the existing wires to run power to the garage and be able to switch it on or off from the house, but to do 3way switching and have constant power, you will need 4 wires plus a ground.
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
rewiring garage - adding sub panel wombosi Electrical 3 05-28-2009 11:08 PM
rewiring garage, questions about conduit pros and cons wombosi Electrical 32 05-08-2009 02:59 AM
Quickly rewiring my garage after feeder cut, messed up the planning, need help. thegonagle Electrical 10 10-23-2008 05:55 PM
