Old 04-13-2010, 01:00 PM   #1
Rewiring A 1948 Bathroom
I gutted the bathroom in a New York house built in 1948. The wiring includes cloth sheathed 12/2 in bx without ground. The bathroom electrical was the end-run of a circuit that services a master bedroom as well as a guest bedroom. I want to place the bathroom on it's own circuit. The house is a tiny one family; the bathroom is small. Will one 20amp circuit with 12/2 Romex be sufficient for two GFCI outlets, vanity lights, recessed shower light, and under-tile heating. Am I asking for too much from one circuit ?
nixplix is offline   Reply With Quote
Old 04-13-2010, 01:08 PM   #2
A "Handy Husband"
rjniles's Avatar
Sounded good until I got to the under tile heating. I would run that on an individual circuit sized by the requirements on that heater. The other stuff on a 20 amp circuit is fine.
Coastal South Carolina
Old 04-13-2010, 02:54 PM   #3
Just call me Andrew
My floor heat for my bathroom will only use 1.5 amp (15 sq feet). I am doing the floor heat on the lighting circuit, and the outlet (i have just one) on its own circuit.
Do you foresee two high-energy devices (hairdryers?) being used at once? If so, may want an extra circuit.
Andrew
secutanudu is offline   Reply With Quote
Old 04-13-2010, 03:03 PM   #4
A "Handy Husband"
rjniles's Avatar
I would run the heat on its own circuit just for ease of trouble shooting if the need arises. I would run the circuit to a wall mounted dead-front GFCI and feed the floor heat of the load side. If you decide to put in a receptacle instead of a dead-front it will have to be a 20 amp circuit.
Old 04-13-2010, 03:26 PM   #5
Just call me Andrew
The floor heat (line voltage) thermostat may have built-in GFCI protection. The SunTouch one I got does.
Andrew
Tags
bathroom, electrical, gfci, heating
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 05:54 PM
Bathroom DWV Layout Problems grymes56 Plumbing 8 05-15-2011 10:00 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
rewiring a basement bathroom - check my wiring please mslide Electrical 2 07-10-2008 07:06 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 11:10 AM
