Rewireing Old House - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 12:02 PM   #1
Lightbulb
Rewireing old house
I'm rewiring a house built in 1947. Adding 100 amp sub panel for new circuits. Question is, when fishing new NM down walls, how can I staple the wire every 4 ft. and within 4 inches of the box? This is the first time I've done "old work" and any suggestions would be appreciated.
dan
danfaub is offline   Reply With Quote
Old 12-13-2009, 12:10 PM   #2
When fishing wire in existing walls you are not required to staple
Only if you open the walls
Old 12-13-2009, 12:17 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
And it is not within 4" of a box. It is either 12" or 8" depending on the box.
Old 12-13-2009, 12:34 PM   #4
Thanks.
Any idea how I get the wire passed the fire block without opening the wall?
Old 12-13-2009, 02:32 PM   #5
Rewards Points: 6,652
Flex Drill bit, or if Gypsum board without a Plaster skim coat, open up a section above & below the FB, and dril. Leave open to help pull the wire.
Old 12-13-2009, 03:37 PM   #6
They sell long 4 or 5 ft. long flexible drill bits at electrical supplies or in electrical departments of some home improvement stores (not tool section!)
These drill bits have a small hole in the end of the bit. So once you drill through, you can attach a small wire to a larger wire and pull it back through the hole.
Billy_Bob is offline   Reply With Quote
Old 12-13-2009, 04:09 PM   #7
Electrical Contractor
kbsparky's Avatar
If those "fire blocks" you encounter are actually "diagonals" good luck. We usually have to open up a section of wall to get around those, as those d'versibits don't work too well dealing with hidden diagonals.
-KB
Old 12-13-2009, 04:54 PM   #8
Thanks all. Since I'm texturing all interior walls, I'll open the walls at the fire block/diagonals and hope I hide all the patches.
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
Brick and block house footer question. ourzoo Building & Construction 2 07-01-2006 02:57 PM
