Rewireing Old House - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 02:53 PM   #1
Rewireing Old House
Hi I have2 houses to rewire the first one i livein it now has 3 Fuse boxes. Main box has 4 fuses other 2 has 2 each. So i am going to put in one breaker box. It has a half basement. I have wired several new houses. but i have some ??? on rewireing. I will have to drill the floorjoist how many wires can i run per hole? I have thought about this is it a good ideal to put junction boxes under the floors and go from their or how is it done? I am looking for a little headsup so when i am done i wont see a easy way that i could have done it.
Mo Guy is offline   Reply With Quote
Old 10-29-2012, 03:09 PM   #2
Rewards Points: 12,856
How old are the houses?
Ballon wall constrution?
Old 10-29-2012, 03:09 PM   #3
Julius793's Avatar
Do you own this house?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 10-29-2012, 07:32 PM   #4
The house i live in I own the other is my dads and no one lives in it. I know what ballon frame is but i am not 100% but i dont think they are. His was built in the Knob and tube era.I dont know the age of my house it has regular wiring with no ground. They both have plaster and lathes.
Old 10-29-2012, 07:51 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
No, this is absolutely not how it's done. Just run from box to box. Drill the floor under the boxes and run the wire up to them.
I get the impression you have not done much wiring. What is your level of experience?
Old 10-29-2012, 08:53 PM   #6
I have wired more than New 20 houses and several shops and Buildings. In my area you dont have to be licensed but it has to be inspected. I can not remember being around a house that was rewired.I have also worked on 3ph and built gen sets for quarrys. All my shop stuff is 3ph runing on a Phase converter that i built.
Old 10-30-2012, 12:04 PM   #7
Rewards Points: 58
Then you need no further help.
Old 10-30-2012, 08:43 PM   #8
I have never rewired a old house and was just looking for some pointer.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 03:54 PM
Mast and weatherhead pulled from house, conflicting information from POCO subcontract SleepnZJ Electrical 1 11-02-2011 10:39 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
