Rewire, Pull Old Wire, Or Leave It. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 10:34 PM   #1
Rewire, pull old wire, or leave it.
I'm doing a base refinish, and Ive got several wires that I've disconnected from previous circuits, and I'm trying to determine the best thing to do with them. As an example, I have a wire that use to go to a pull light in the basement, it was run from the pull light, through the floor, into the den on the first floor; into an outlet box. I've already disconnected at both ends, and shorted all wires at each end to each other. But, not sure if that is the best option.
Should I?:
1). Do just what I've done, and bundle each end, so that black white and ground are all shorted to each other, at both ends. Then, in the one hanging from the basement joists, do I need to stuff it into a JB, or can I just wire tie it to the underside of the joists? I WILL be putting in a drop ceiling, so I would have access to the wire and or the JB.
2). Should I try to pull the wire out? I think that I might be able to pull at least the core Wires out and leave only the romex sheathing. I haven't tried yet though.
3). A better option?
rrunkle is offline   Reply With Quote
Old 01-31-2012, 12:39 AM   #2
Julius793's Avatar
Disconnect and take it out out the panel first!! After that it's not live and doesnt have potential to become live, therefore do what ever makes you happy.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-31-2012, 02:56 AM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What if it isnt fed from the panel?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 01-31-2012, 06:44 AM   #4
Rewards Points: 1,506
A wire or cable known to be disconnected at both ends may be left buried in the wall. If the cable is unusable, such as having crumbling insulation, it is best left with wire ends cut flush with the sheath (or individual wires left with conductor cut flush with the insulation).
Better not to short the wires to each other.
Old 01-31-2012, 06:58 AM   #5
Not coming from the panel.
Old 01-31-2012, 07:07 AM   #6
Julius793's Avatar
Same thing, where ever it's fed from disconnect it and remove it, don't just short it.
Old 01-31-2012, 11:40 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 424
Cut it off as close as you can in the back of the box, and cut it off as close as you can where it comes out of the wall.
You don't want to be there a year from now asking yourself why is that wire there.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
plummen (01-31-2012)
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 06:02 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
How much wire to leave in box? Nhrafan Electrical 7 04-13-2007 04:03 PM
ok to leave chandelier third wire unconnected? gonzales9 Electrical 5 01-12-2006 08:10 PM
