Rewire Part Of House Without Tearing Out Walls? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-08-2013, 01:30 AM   #1
Rewards Points: 682
Rewire part of house without tearing out walls?
I recall a contractor telling me he could rewire the kitchen from the main breaker box by 'pulling' the wires through the walls. From what I've seen this would be impossible, with wires running up and down and twisted together and drawn thru tiny holes in the studs. What do you guys think? Our attic also is too small to enter.
darsunt is offline   Reply With Quote
Old 12-08-2013, 01:55 AM   #2
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
You must cut holes everywhere at least.
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 12-08-2013, 07:00 AM   #3
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
hard to tell without seeing it ... you would be suprized what you can do ...
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
plummen (12-10-2013)
Old 12-08-2013, 09:31 AM   #4
deverson's Avatar
Rewards Points: 77
Cut holes, run new circuits, patch holes, install a tile backsplash.
deverson is offline   Reply With Quote
Old 12-09-2013, 12:03 AM   #5
Rewards Points: 682
The breaker box is on the outside wall behind the living room. The living room is between the breaker box and the kitchen.
I can imagine tying a wire to the end of the circuit wire coming out of the breaker box, and then pulling it all the way through to the kitchen. But I think there would be too much friction.
Old 12-09-2013, 12:04 AM   #6
Rewards Points: 682
Also could imagine running wire from breaker box through attic, and drop it down to the kitchen. However I believe our attic space is too small to crawl about in. Also that would be against most codes?
Old 12-09-2013, 12:14 AM   #7
nah, there is nothing in the code explicitly prohibiting wiring through an attic.
itsnotrequired is offline   Reply With Quote
Old 12-09-2013, 01:46 PM   #8
Rewards Points: 336
An accessible attic is in fact a great way to run wire when retrofitting electrical.
JKeefe is offline   Reply With Quote
The Following User Says Thank You to JKeefe For This Useful Post:
Old 12-09-2013, 08:27 PM   #9
eastcoastsparky's Avatar
Rewards Points: 150
Get in that attic and be a man lol, but seriously as electricians im sure my fellow sparkys will back me up we go in many nasty super tight spaces that we dont wanna go in but if it means getting the job done then oo well we deal with the annoyingness for a couple hours. Alot of times attics are very very helpful when doing rewire retrofits
eastcoastsparky is offline   Reply With Quote
Old 12-09-2013, 11:20 PM   #10
Msradell's Avatar
Rewards Points: 90
I always thought that tight attics or what apprentices were for!
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
Old 12-10-2013, 09:48 PM   #11
Rewards Points: 820
Maybe they could run conduit outside the house, and put a sub-panel in the kitchen? I have seen houses with conduit running outside, but it's mostly for central AC units that have to be located outside. Still, if it's either that or cutting lots of holes and fishing / pulling cable through walls, I would expect the external conduit to be less expensive.
FW
Ultrarunner2017 is offline   Reply With Quote
HELP! WHAT is this weird "wire" running through the walls of my house??? leatherlips Electrical 7 09-22-2013 10:34 AM
Insulating Exterior Walls in an Old House jerseyguy1996 General DIY Discussions 2 10-13-2009 11:11 AM
Insulating walls of old house saturn78 Building & Construction 8 07-02-2009 01:04 PM
My house is a project...Part II "Deck Evolution" tigerbalm2424 Project Showcase 21 07-24-2008 11:37 AM
Need to Jack up part of my house.... harleysilo Remodeling 24 10-01-2006 09:05 AM
