To Rewire Or Not?? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 07:13 PM   #1
Fire6Dude's Avatar
To rewire or not??
Hello, I could use a little help and input.
Here's my situation. I have a duplex built in 1922. It has some Knob and Tube wiring, some old cloth wiring and some new wiring. All receptacles, switches, lights are in perfect working order. I have a 100 amp breaker panel. Heating is natural gas boiler. Insurance company has insured me knowing my electrical system.
I plan on remodelling my kitchen, expanding it into another room. I called two licensed electricians to give me a quote.
First electrician said he will have to rewire my entire unit. Drill holes in my plaster and lathe walls, fish all new wires and bring everything to up code. $10,000+
Second electrician said to leave K&T and old wires alone. He said many houses still have perfectly working K&T wiring. If there are no flickering lights or tripping breakers then there is no problem. I have 7 unused slots in panel which is more than enough room for a dishwasher, fan, etc... He said to save my money and troubles with patching up plaster walls from fished wires.
I like the idea of having a safe, up to code, brand new electrical system in my home. But I also like the idea of saving the $10,000. If it aint broke don't fix it??? What do you guys think??
Thanks ahead of time
Fire6Dude is offline   Reply With Quote
Old 02-14-2013, 07:16 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Hire the second guy.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following 4 Users Say Thank You to electures For This Useful Post:
k_buz (02-14-2013), MCB (02-14-2013), NJMarine (02-15-2013), TarheelTerp (02-14-2013)
Old 02-14-2013, 08:28 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,142
Ditto.....
Old 02-14-2013, 09:53 PM   #4
Rewards Points: 1,548
K&T wiring that has soldered joints and which is taut enough so conductors don't sag and touch is actually extremely robust. It would have no more problems with loose connections than new wiring where the most connection problems happen inside outlet boxes and where fortunately you can open up the box and fix the problems.
Old 02-14-2013, 10:39 PM   #5
Electrical Enthusiast
Rewards Points: 504
I personally agree with the above posters. If you're not having problems, there's no need to upgrade.
However, DO keep in mind that K&T is not supposed to have insulation covering it, it needs the air space for heat dissipation.
Kyle_in_rure is offline   Reply With Quote
Old 02-15-2013, 07:25 AM   #6
Licensed electrician
Rewards Points: 1,892
One issue is if you want to insulate and the K&T is in the way, you cannot insulate around it.
Old 02-18-2013, 07:48 AM   #7
Fire6Dude's Avatar
Thanks for the quick reply. The official quote from the first company was just over $12,000. So I decided to go with the second option, keep the original wiring and bring in new circuits when I remodel the kitchen.
Thanks again
Old House Rewire Primer LTParis Electrical 8 05-03-2012 12:02 AM
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Am I going to have to rewire my house? dukes909 Electrical 14 09-14-2010 05:11 PM
old lamp post rewire tiso2010 Electrical 1 08-08-2010 05:59 PM
Upgrade or rewire Lexiesmom Electrical 4 06-30-2010 08:21 AM
