Rewire - Electrical - DIY Chatroom Home Improvement Forum
Old 06-28-2011, 01:21 PM   #1
rewire
How do i get a wire down thru an insulated wall from attic to basement?
Tom Martin is offline   Reply With Quote
Old 06-28-2011, 01:33 PM   #2
Preferably on an interior wall with no insulation. You will have to become familiar with your building's construction and utilities. If you have power in basement that must control a device in attic, see if any existing wiring already travels that path. More details needed for better advice. Just power or a switch?
diyorpay is offline   Reply With Quote
The Following User Says Thank You to diyorpay For This Useful Post:
Tom Martin (06-28-2011)
Old 06-28-2011, 01:59 PM   #3
Living Life
depending on how much voltage you are going to run through the wire, you may want to try one of those steel fish tapes. i've used that before and had no problem at all getting through insulation.
DavidRobinson is offline   Reply With Quote
The Following User Says Thank You to DavidRobinson For This Useful Post:
Old 06-28-2011, 02:14 PM   #4
Electrical Contractor
Fish sticks
http://hardware.hardwareandtools.com...berglass%20Rod
hpp58 is offline   Reply With Quote
The Following User Says Thank You to hpp58 For This Useful Post:
Old 06-28-2011, 02:14 PM   #5
Rewards Points: 1,512
Fish tape can be used with all household grade cables (Romex type) and voltages (120/240).
Sometimes you need to use two fishtapes, one inserted from each end of the pasage way and you play dueling swords inside the wall, then you pull the hooked ends out one hole, attach the wire, and pull the wire through.
Other times you have to cut square holes say 3x3, here and there through the drywall or paneling along the route you need to run the cable. This is most often needed when the wire has to go horizontally a little, through a stud or two.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 06-28-2011, 03:06 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Much preferable to fish an inside wall with no insulation. The problem with fishing a insulated exterior wall is that you tear up the insulation and vapor barrier.
If you have to cut holes in the drywall to get around fire blocking, I like to use a 5" hole saw. Then drill a 3/4" hole in the blocking for the wire. Secure the round piece of drywall with a few screws and tape and mud.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Rewire 1955 house gemini28 Electrical 3 11-22-2010 11:27 PM
Am I going to have to rewire my house? dukes909 Electrical 14 09-14-2010 05:11 PM
Upgrade or rewire Lexiesmom Electrical 4 06-30-2010 08:21 AM
Aluminum rewire plan ra_doliv Electrical 13 07-06-2007 05:37 PM
