Review My Kitchen Circuit Plans - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2008, 09:30 AM   #1
review my kitchen circuit plans
I am remodeling my kitchen from the ground up, and am at the point where I am planning my circuits, and was wondering if you would review my plans to make sure they make sense.
I plan on having 7 circuits as follows
#1 20 amp lighting. I want to have 4 recessed over head lights, and 1 set of under cabinet lights
#2 20 amp oven and refridgerator. I have a Gas oven, this should be fine to put both on the same circuit right?
#3 20 amp microwave. I am planning on getting one of the over the range microwaves, these don't require a separate circuit for the "hood" part of them right?
#4 20 amp dishwasher
#5 20 amp garbage disposal
#6 20 amp receptecles on left side of kitchen
#7 20 amp receptecles on right side of kitchen
How does this sound to you guys? I know its kind of vague, but at a high level does it seem to make sense?
DanBress is offline   Reply With Quote
Old 03-08-2008, 10:14 AM   #2
When is fishing season?
CowboyAndy's Avatar
6 and 7 are going to be supplying the countertops, right? Will there be any outlets in the kitchen (besides fridge, stove, micro, etc) at all?
Make sure your spacing is correct for the countertop receps and make sure they are properly gfi protected.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-08-2008, 03:23 PM   #3
Yes 6 and 7 are JUST for countertops, and no there will not be any other circuits. They will all be GFCI
I have a very small kitchen(8x10), and basically all wall surfaces are covered by either door ways, counter tops, or appliances.
There is one place that COULD have an outlet. Its a galley style kitchen, and on the far wall between the counters. However there is a window on the top half of the wall, and a radiator on the bottom part. There wasn't an outlet there before.
Old 03-08-2008, 04:05 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
You can share the disposal and dishwasher.
Old 03-08-2008, 04:14 PM   #5
Here is a picture of the kitchen with everything ripped out:
The kitchen is approx 93" wide, with 19" counter tops on each side, this leaves 55" between the counters. But this is above the radiator, and below the window. would the code require a breaker on this wall? where would it go?
Old 03-08-2008, 04:14 PM   #6
Rewards Points: 1,274
Put your lighting on a 15a. Don't GFCI protect it. Don't GFCI protect the refrigerator either.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-08-2008, 05:12 PM   #7
Also I was planning on running 2 wire for everything, is there a reason to run 3 wire?
Old 03-08-2008, 05:31 PM   #8
Electrician
#1 20 amp lighting. I want to have 4 recessed over head lights, and 1 set of under cabinet lights.
I would run a 15 amp circuit, but its your money.
#2 20 amp oven and refrigerator. I have a Gas oven, this should be fine to put both on the same circuit right?
I would also pull a 15a for the fridge, but again its your money.
If the Microwave is over the range then it must be a Individual Branch Circut.
Install receptacle under sink, install pre-made cord on dishwasher. You need a disconnect anyways.
Plug GD into dishwasher receptacle... Same circuit as Dishwasher, just 1/2 switch the receptacle for the disposal.
You need two minimum circuits, so this will work
Same as above.
chris75 is offline   Reply With Quote
Old 03-08-2008, 05:36 PM   #9
CowboyAndy's Avatar
As long as you mean 2 wire plus ground, then there is no need to run anything 3 wire. only 120/240 volt requires 3 wire plus ground.
MY HOUSE OWNS ME!
Old 03-08-2008, 06:07 PM   #10
Sounds good.
Combine the DW/Disp.
The refer can be on the c/top circuit (before the gfci) but it is a good idea to separate it. The more circuits the better. I ran 4 ctop circuits and a dedicated 20 for the fridge in my kitchen.......just because I could.
2 wire circuits are GOOD.
220/221 is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Number of circuits needed for a small kitchen? All responses welcome! alexz Electrical 5 04-07-2007 10:38 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
