Reversing Single Phase AC Motor - Electrical - DIY Chatroom Home Improvement Forum
Old 04-24-2013, 10:42 AM   #1
Is there any way to add a switch of some sort to quickly change direction of rotation on an AC motor (drill press for example)?
Aaron
amusall is offline   Reply With Quote
Old 04-24-2013, 11:05 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Yes either a 3 phase reversing starter or a drum switch.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 04-24-2013, 06:43 PM   #3
Idiot Emeritus
Rewards Points: 1,492
While a drum switch will certainly work, a two pole toggle switch that's rated for the HP of the motor will work too.
I'll need to know the motors lead numbers; most likely they are T1 through T5 and T8.
Post the lead numbers, and I (or one of the other motor guys) will post how to connect the switch. It's not very hard.
Rob
micromind is offline   Reply With Quote
Old 04-24-2013, 07:10 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,098
Aaron
What type of motor ?
single phase ?
Three phase ?
Universal motor ?
Or induction motor ?
dmxtothemax is offline   Reply With Quote
Old 04-24-2013, 07:38 PM   #5
Rob
This is exactly what I was thinking. I'll get you the wiring specs tomorrow. Is there anyway a foot pedal could be incorporated where it's forward without hitting the pedal but reverses only while your foot is in the pedal? Does the switch you suggest have to be on off on or can it be on off?
Aaron
Old 04-25-2013, 12:01 AM   #6
Idiot Emeritus
Aaron
A foot pedal could be used, but it'd involve a relay which would have to be mounted in a separate box.
The switch can be either fwd-off-rev or fwd-rev and on-off with another switch.
A basic standard single phase motor cannot be reversed while it's running. It has to be mostly stopped in order to change direction of rotation. This is because the start winding needs to be engaged for rotation direction.
3 phase 3/4 motor switch gustonlemond Electrical 5 08-28-2012 12:45 AM
Single Phase Panel from Three phase 3 Wire Delta bsps Electrical 9 06-02-2012 09:44 PM
3 Phase to single phase conversion fabricator Electrical 21 02-22-2011 10:16 PM
Converting 3 phase equipment to single phase /VFD? lightison Electrical 7 01-04-2011 04:14 PM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 07:55 PM
