Reversed Wires While Changing Light Switch. Circuit Blew. Damage? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 08:34 PM   #1
reversed wires while changing light switch. circuit blew. damage?
While trying to change a light switch, I switched the wires which caused a spark and the circuit went out. Could I have damaged electronics on that circuit or damaged wiring in the building or do I just need to change the fuse bulb and everything will be fine?
asterix2k10 is offline   Reply With Quote
Old 09-02-2013, 08:48 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Why are you changing switches hot?
Just reset the breaker or replace the fuse.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
plummen (09-03-2013)
Old 09-02-2013, 09:05 PM   #3
Rewards Points: 150
How did you reverse the wires in a switch? Your stuff should be fine. I don't recommend you change anymore switches cause you could damage electronics by constantly doing that
romex1220 is offline   Reply With Quote
Old 09-02-2013, 09:28 PM   #4
The wires got switched because after wiring it normally the light didnt work so I stupidly thoufht maybe try hooking the wires up reversed. Then when I turned the power on it sparked and the power on that circuit died. I need to get the right fuse to replace the fuse but in the mean time am wondering if the tvs, computers, audio equipment, etc on that circuit might have gotten damaged.
Old 09-02-2013, 09:38 PM   #5
DIY staff
Rewards Points: 7,174
Very unlikely---sounds like you had a dead short---power surges kill equipment,so I bet you are fine.
Old 09-02-2013, 09:52 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Unless they have MWBC ( Multi wire branch circuit ) some case it will affect some of the electrique items and with MWBC's the netural conductor can take a lot of blunt but not always the case.
Pour Le OP.,, ( for the OP )
There is a reason doing the switch change when the source is still on ??
If you did get black et white transponed you will open new cans of worm.
If this switch a single pole it very easy to swap a new switch without issue.
If this is 3 way switch then you will have to pay attetion to which conductour is common and other two is shuttle ( traveller )
Merci,
Marie et Marc
Old 09-02-2013, 09:56 PM   #7
The original switch had two screws to connect wires on the right side. The new switch had 2 plus one more on the left side. But there are only two wires. Could this be why the switch didnt work?
By the way I did turn the circuit off before changing the switch.
Old 09-02-2013, 10:22 PM   #8
Bonjour .,
Ok , did you transfer the conductors from the old switch to the new switch the same way as the old one was ? if so that is correct and the third screw on left what colour it is ??
If that was green then it is a earth ( ground ) screw but if differnt colour let us know right away.
Merci,
Marie et Marc
Old 09-02-2013, 10:54 PM   #9
Rewards Points: 150
You have a three way switch. You might have connected the neutral or ground to one of the travelers giving you a dead short
Old 09-02-2013, 10:57 PM   #10
Maybe so but if the OP did mention just two screw on old switch while the new one have three screw and need to confirm which colour the third screw is ( We have a huntch that is earth screw )
Merci,
Marie et Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
Old 09-03-2013, 02:12 PM   #11
Rewards Points: 170
rather than waiting for a reply on here, go to your local supply store, get a fuse, and find out for yourself.... gonna have to eventually anyway. best answer to your question that I see
diyer111 is offline   Reply With Quote
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Wiring 2 light fixtures to same switch and add outlet RyanS2000 Electrical 13 10-10-2010 03:17 AM
Problem changing light switch grgryl Electrical 14 08-10-2008 02:26 PM
Changing Light Fixture - Way too many wires and light wont switch off marapapa Electrical 3 01-13-2006 02:16 PM
