Reverse Current? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 04:03 PM   #1
Reverse current?
I do some soldering and minor welding in my shop. I need to ventilate the space with fresh air intermitanly. The fan is hooked up to a controller with a 120v plug. I also need to heat/cool this room but having the heater or air conditioner on when the ventilation is on seems like a bit of a waste. Is there something I can plug into the controller that tells the heat/ac to switch off when the power to the controller activates? The ac and heater are both portable with 120v plugs.
danross is offline   Reply With Quote
Old 02-26-2010, 07:33 PM   #2
Insert catchy title here
AppleMac*Fit's Avatar
Motor controller. Normally closed contactors assign to the heat/ac, normally opened controllers assign to the ventilation fan.
AppleMac*Fit is offline   Reply With Quote
AFCI Breakers Keep Tripping mopowers Electrical 12 09-04-2009 04:11 PM
Kinetico Water Softeners -Reverse Osmosis Questions...Help - Advice wanted.. OverRunWithSons Plumbing 7 07-26-2009 01:14 AM
Ground rod or not? brotherman Electrical 30 07-15-2008 05:58 PM
80 leds for led light. can i run to 230v mains donnol1983 Electrical 8 12-27-2007 07:23 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 02:23 AM
