Reusing Abanonded Wire For Pigtails Or Other Purposes? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 08:29 AM   #1
mysterd429's Avatar
Reusing abanonded wire for pigtails or other purposes?
Hi all. I'm working on my basement workshop. and I'd like to put in outlets on switches in two-gang Wiremold-type boxes. There's a bunch of abandoned Romex-type wire in the workshop. (I tested it with voltage detector and digital multi-meter.) Can I use the sections that aren't crimped by staples or beat up on the ends for pigtails in the boxes? I know I need THHN for inside the channels, but can the abandoned wire be reused for other purposes it's long enough and not crimped?
mysterd429 is offline   Reply With Quote
Old 10-21-2012, 08:45 AM   #2
seansy59's Avatar
Rewards Points: 258
Honestly. If it was me, I would just buy a new $10 roll of Romex for new work. Unless the wire is in fantastic shape, never installed, and complies with todays standards (ie. not ungrounded cloth wire from the 50's on a new roll), I always like to use new items for things that are a new install. Personally it just makes me feel more confident that I won't have to rewire a new piece that failed within a month, just because I wanted to save $10.
seansy59 is offline   Reply With Quote
Old 10-21-2012, 08:55 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I wanna know where you are buying romex for $10 a roll?
Sure, go ahead and use it.
The Following User Says Thank You to k_buz For This Useful Post:
electures (10-22-2012)
Old 10-21-2012, 09:39 AM   #4
seansy59's Avatar
Rewards Points: 258
HD. If he only needs short lengths of 1-2ft for in box wiring, then they sell 15ft rolls of 14/2 for $10.
The Following User Says Thank You to seansy59 For This Useful Post:
mysterd429 (10-25-2012)
Old 10-21-2012, 09:51 AM   #5
Rewards Points: 6,652
I keep all extra Romex on a shelf, for this use. As long as it is in good shape, using for pigtails in circuits, should be no problem.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 10-21-2012, 11:20 AM   #6
joed's Avatar
Rewards Points: 12,436
Using the wires from inside NM cable for 6" pigtails in a box is normal operating procedure. It is not OK to use for the wires in the wiremold channels.
The Following User Says Thank You to joed For This Useful Post:
Old 10-21-2012, 01:57 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
To the original poster:
Wondering why you want to use WireMold. PVC is cheaper and easier to use. PVC is not pretty but in a shop most would not care.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 10-25-2012, 04:48 PM   #8
mysterd429's Avatar
Sorry for the delay in replying. Honestly, I didn't think to use PVC simply because I didn't think of it. I've already bought some of the Wiremold stuff and installed the starter box. The space is pretty small, so I'll check to see if it makes more sense to switch to PVC. I do care more about aesthetic than is rational but not that much.
Would this be the sort of box I'd need for PVC, or would there be another sort? Thanks!
As for reusing the old wire, I'll stick to using it just for pigtails on this project and put the rest on the shelf.
Old 10-25-2012, 05:04 PM   #9
A "Handy Husband"
rjniles's Avatar
That's the type box, lots of other configurations available.
Or this:
or this
Old 10-25-2012, 06:44 PM   #10
mysterd429's Avatar
Thanks for your reply. I haven't worked with PVC before. How does the conduit attach to the boxes? If the conduit is threaded on both ends, do you leave the next box that you're installing unattached from the wall, to screw it onto the conduit, then attach it to the wall? Or is there some other mechanism? Does the THHN rule apply to PVC conduit as well? Thanks again!
Old 10-25-2012, 06:54 PM   #11
Pure Genius
Rewards Points: 150
You buy box connectors for the pvc and glue them on.
Dierte is offline   Reply With Quote
Old 10-25-2012, 06:57 PM   #12
A "Handy Husband"
rjniles's Avatar
The PVC boxes you showed are cemented directly to the conduit. The metal boxes I showed use a threaded male adapter cemented to the conduit. THHN /THWN wire is used.
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
Dimmer switch with Hot & Neutral wire ? Knucklez Electrical 3 12-28-2010 04:24 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
