Reuse Existing Intercom Wires For Low Voltage Power Source? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 08:07 AM   #16
Retired from the grind
gregzoll's Avatar
Rewards Points: 6,638
Not code compliant. Use DB9 connectors to attach the USB to the existing wiring. Intel's white paper on USB Drop & Droop http://www.otdl.com/VDROOP.PDF Do a search, you can find some info on building your own USB charging circuit, vs. trying to find a power supply that is non-compliant.
Still think that it is easier to just pull up the 120vac wiring and/or just lay the unit on a table to charge. As for question before, what are the docking stations & tablets that you plan on using for this?
Ren: Now listen, Cadet. I've got a job for you. See this button? Ren: Don't touch it! It's the History Eraser button, you fool! Stimpy: So what'll happen? Ren: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Ceiling Fan Install power source at fixture uaw239gm Electrical 17 01-09-2011 08:50 PM
need power source badluck Electrical 2 08-05-2009 03:44 AM
Wiring diagram to move switch in box w/3 way wires and source columbuskat Electrical 4 01-30-2009 12:32 PM
Undercabinet lighting power source? Ideas? PDubs Electrical 7 01-28-2009 04:37 AM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
