#1 |
Reuse electrical box with punchouts removed
I just removed two punchouts in a box, realized that they won't work where I need them, is the box junk or can I just use the other punchouts and leave the original ones open?
#2 |
The unused openings need to be closed (110.12(A)). You should be able to find an "oops plug" to fit the KO's.
#3 |
Licensed Electrician
The box isn't junk. You can still use it, but I highly recommend you don't leave the holes open. Inexpensive knockout fillers are available that snap in to the holes to close them. It is a code requirement that unused holes be sealed.
#4 |
Are they available for romex tabs or just the half inchers?
#5 |
I've never seen them for Romex tabs, just round holes from 1/2" up.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#6 |
Thanks, that pretty much answers my question. If anyone knows if they exist for romex knock outs as well, let us know.
#7 |
Creative Electrician
Ok, if your talking about the little black push buttons, just take the button back out and use a "push Penny".
#8 |
Reuse electrical box with punchouts removed |
#9 |
For lack of a better description, it looks like a plug. It has a flat surface, and little feet that connect into the knockout hole. Any Lowe's, Home Depot or supply house should have one.
#10 |
Licensed Electrical Cont.
He means a knockout seal.
I have never heard the terms "oops plug" or "push penny" either. Not even online.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#11 |
Electrical Contractor
I have heard the plastic ones called a push peeny, but the metal ones were always called KO seals.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
| Display Modes | |
| low-voltage and electrical wiring sharing same stud space | jheavner | Electrical | 21 | 10-06-2011 12:16 PM |
| Just for fun | Andy in ATL | Electrical | 56 | 10-20-2009 10:33 AM |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
| Electrical Box near Shower Valve | dasajame | Electrical | 3 | 07-07-2008 07:46 AM |
| 2 Prong Electrical | mjcongleton | Electrical | 10 | 04-16-2008 09:59 AM |
