Return Air Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2008, 02:14 PM   #1
Rewards Points: 518
Return air question
In one room, there is a return air duct inside ceiling joists. It does not take the entire cavity up from end to end, just a few feet into the room and then its capped off inside the joist with that shiny thermal cardboard. About 8ft away, in the same joist span is a light box. From where the return air ends and the light box is, the cavity is fully insulated with R20.
I know that romex can pass through return air joists, but not run parallel or have a box placed inside. Since this light box is not officially inside a return air duct, and has the thermal pan and insulation, is this ok?
n0c7 is offline   Reply With Quote
Old 10-19-2008, 03:14 PM   #2
Electrical Contractor
kbsparky's Avatar
yup
Old 10-20-2008, 10:09 AM   #3
Rewards Points: 518
The emoticon makes me wonder......
Old 10-20-2008, 01:20 PM   #4
Its good, but if you want, you could drill through the joist and run the wire in a different joist space, unnecessary, but easier without that duct in the way.
rgsgww is offline   Reply With Quote
Old 10-20-2008, 01:23 PM   #5
Registered User
Termite's Avatar
It is widely accepted that when an electrical box or lengthwise wire occurs in a duct (which this effectively is), that you can pan off that box or wire to isolate it from the duct airspace.
This can be done with wood, sheet metal, or thermopan (the foil faced cardboard you described). As long as it is done tightly the hazard has been effectively mitigated. In the event of an electrical fire, they don't want the burning wire to immediately introduce toxic by-products into an HVAC system that conveys air.
Wires can pass through the duct, but not along its length. Most inspectors will be reasonable enough to recognize that running a foot or so across a duct is no different that running a foot or so lengthwise in the duct. But, per code, you cannot have romex paralleling the duct inside it.
Old 10-20-2008, 09:16 PM   #6
Rewards Points: 518
Is there any restrictions on how far or close you can box off from?
Old 10-20-2008, 10:47 PM   #7
Registered User
Termite's Avatar
It would be up to the inspector that is being asked to approve it. Ideally, any panning that takes place in an HVAC run won't block too much of the duct's cross-section.
Old 10-21-2008, 05:21 PM   #8
Rewards Points: 518
Sorry to sound like a knob, ducts cross section?
Old 10-21-2008, 05:51 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
If I'm understanding correctly you have a ceiling box sharing the same joist cavity but not inside the return air duct. If is isn't inside the duct and the wiring isn't inside you can run parallel to the duct, over it whathever you want. As long as the romex is fastened correctly as per Art. 334 and not inside the duct space I don't see any issue.
Old 10-21-2008, 07:55 PM   #10
Rewards Points: 518
Yep, exactly. Just wanted to ensure that wiring could be run anyway you want and if any type of electrical box(light box, junction, receptacle, etc) could also be located in that cavity as long as its not inside the return air duct as this is what I have except there is a distance of about 8 feet between where the return air is capped off with thermal pan and duct tape, and insulation in between.
Cold air return question bubbles HVAC 1 06-05-2008 08:40 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 12:43 AM
HVAC return vent location question fatboy HVAC 1 03-10-2008 08:56 PM
