Retrofitting Recessed Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 08:53 PM   #1
Rewards Points: 85
Hi!
So here's the scene..
Old house.
Attached garage converted to a family room.
Pitched roof above.
Recessed lights existing in the high point between the roof rafters and ceiling joists....
Question:
Want to install two additional recessed lights at the other end, or the low point between the roof rafters and ceiling joists. I
I'm sure there is insulation. Should I install the recessed lights and remove enough insulation around them to clear a min of 3", or something else? Please be specific...
Thanks!!
JohnC20 is offline   Reply With Quote
Old 12-04-2012, 09:49 PM   #2
Licensed electrician
Rewards Points: 1,892
Unless you are installing 4" recessed you should just install an IC rated fixture. This way the insulation can touch the housing and not create an energy leak. Your area may also require AT (air-tight) housings.
Old 12-05-2012, 06:07 AM   #3
Rewards Points: 85
Great!!! I am worried about the clearance or space between the roof rafters and ceiling for the recessed lights. Thanks!
Old 12-05-2012, 03:02 PM   #4
Rewards Points: 150
JohnC20,
You could also consider frame out and drywall for a "drop" to allow enough space for the light fixure. Case in point, something simliar to a tray ceiling along the wall... Just a thought...
oodssoo is offline   Reply With Quote
Old 12-05-2012, 03:39 PM   #5
Rewards Points: 85
Originally Posted by oodssoo
JohnC20,
Yeah.. That is a good point. Unfortunately it's for a friend and he's not looking to redo his ceiling.
Help with Replacing Recessed Lighting from the 80's scubakathy84 Electrical 2 11-03-2012 04:57 PM
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Recessed Lighting under hot/cold supplies?? KC10KEVIN Electrical 1 05-08-2008 10:21 PM
