Retrofit T12 To T8 Master /slave Fixtures - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2010, 11:23 AM   #1
Retrofit T12 to T8 Master /slave fixtures
We are retrofitting Master/Slave fixtures from T12 to T8 ballasts the T12's have many more wires do we just gang wire to the new T8 ballasts?
Jeff77 is offline   Reply With Quote
Old 12-30-2010, 11:26 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
For ease of troubleshooting in the future, I put a ballast into each fixtur.
I hat the system yoou have.
You have to make sure that the tomstones are shunted in order for the t-8 to work.
jbfan is online now   Reply With Quote
Old 12-30-2010, 12:24 PM   #3
Your ballasts should have a wiring diagram on them. different types / brands are wired slightly differently, so there's no one answer. If you can't figure out the diagram, perhaps you should get an electrician.
Note: More electricians are killed working on fluorescent lights than anything else. Be careful, they are high voltage, that's what a ballast does.
JPraski is offline   Reply With Quote
Old 12-30-2010, 04:27 PM   #4
Rewards Points: 150
More electricians are killed working on fluorescent lights... because more electricians WORK ON fluorescent lights.
That said. Most of the electronic T8 ballasts have both pins on the end of the tube attached together. In retrofit, this is achieved by connecting both of the socket wires with a wirenut.
I've even seen this done on some old "preheat" (think starter) types, and without bypassing the starter socket even!
emolatur is offline   Reply With Quote
Old 12-30-2010, 04:32 PM   #5
1/2 true. I also think more electricians take them for granted and aren't as careful as they should be. I don't know anyone who has gotten poked twice by the HV, though. You learn quick.
Old 12-30-2010, 04:57 PM   #6
joed's Avatar
Rewards Points: 13,696
Yes gang the wries. The T12 will two wires per tombstone. The T8 only has one. Just tie the two existing wires to the single wire of the new T8 ballasts. We do it that way all the time. Just make sure you use the correct wires, because the T12 wiring scheme uses the same colours but for different purposes.
Old 12-30-2010, 10:13 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Ya have to becarefull some of the T-8 Electronic ballast do come in either instat start or rapid start so watch out the connection setup and follow the diagram very carefull that is the only way you can do it right.
Merci.
Marc
No power to light fixtures or switch in garage mrsirmrman Electrical 5 09-29-2010 03:36 PM
Master Bathroom Fixtures mpt1123 Plumbing 1 03-01-2009 04:08 PM
Replacing Bathroom Light Fixtures, going from one to two. diynewb Electrical 3 11-25-2008 10:16 AM
Advice on replacing bathroom fixtures t1000 Plumbing 3 07-11-2008 02:42 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
