Retro Barn Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2008, 05:08 PM   #1
Retro Barn Wiring
When I was little (a long long time ago), I seem to remember that my grandfather had his barn fed by a single overhead hot wire.
I'm I mistaken? If not, how was this possible without a neutral?
Randell Tarin is offline   Reply With Quote
Old 02-19-2008, 06:19 PM   #2
Rewards Points: 2,350
At one time alot of folks did this. It is called SWER, single wire earth return. He was relying on the Earth as the other leg of the circuit. Bad idea.
InPhase277
Old 02-19-2008, 06:21 PM   #3
World famous jerk.
Okay, I'll call BS. SWER doesn't work at customer secondary voltages.
mdshunk is offline   Reply With Quote
Old 02-19-2008, 06:26 PM   #4
Well I did say it was a bad idea. That doesn't mean it wouldn't power a few light bulbs or a radio. No doubt they were dim, but I bet they worked.
I know for a fact that the Earth will carry enough current to light a lamp, because I once had a service call about about dim lights and struggling motors in a remote workshop. I investigated and found a lost neutral on the 2-wire subfeed. The ground rods were completing the circuit.
InPhase277
Old 02-19-2008, 06:37 PM   #5
Electrician
InPhase277
How do you know it wasnt the phone or catv supply?
chris75 is offline   Reply With Quote
Old 02-19-2008, 06:41 PM   #6
And before I get flamed, yes I said 2-wire. Some jackleg previous to the current HO ran two black #10s in a water pipe and grounded the neutral at the 8-circuit fuse panel in the workshop to a driven pipe. I ripped it all out.
InPhase277
Old 02-19-2008, 07:03 PM   #7
Rewards Points: 266
Do you have any memory of how big it was?
It could have been a 18/2 or larger extension cord...
junkcollector is offline   Reply With Quote
Old 02-19-2008, 08:31 PM   #8
It wasn't an extension cord. The line ran from the house to the barn. I seem to remember it transversing a couple of poles with insulators on them.
I was curious, because from what I've read in this forum, I knew that the ground wasn't that great of a return path.
Old 02-19-2008, 09:12 PM   #9
Power Gen/RS Engineer
Rewards Points: 566
No, no, this was a great system. Adaptive light control I think they called it. When it was sunny out, the lights automatically dimmed. When it got cloudy and rained, the lights automatically got brighter to compensate.
Now that's technology!
I'm glad I read this. When I saw retro in the title, I got scared thinking that all the kids were suddenly kickin' it oldskool with K&T (duuuuude, my analog sounds WAAAAAAY better with K&T).
Jimmy
Well, now, there's what's right and what's right and never the twain shall meet.
BigJimmy is offline   Reply With Quote
Old 02-19-2008, 11:58 PM   #10
How in the heck did the old timers manage not getting electrocuted. Wouldn't you get a little bit of a jolt if you accidentally touched the ground?
Old 02-20-2008, 01:06 AM   #11
You'd have to touch the ground at two points far enough apart for the difference in potential to be large enough for a shock. You might have to stretch.
InPhase277
Old 02-22-2008, 07:33 PM   #12
fasinating jim...
bullet is offline   Reply With Quote
Old 02-22-2008, 10:04 PM   #13
Union Electrician
goose134's Avatar
You mean like if you were running back to your truck after seeing it?
goose134 is offline   Reply With Quote
I've lost power at my barn Jim Owens Electrical 11 10-11-2008 10:58 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
Wiring a Pole Barn rocky Electrical 8 02-02-2006 06:34 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
