Retired Engineer - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2009, 04:48 PM   #1
retired engineer
can I use two number 10 (awg 2 wires with ground) in place of one number 8 (awg 2 wires with ground) to supply an AC compressor
potatochip is offline   Reply With Quote
Old 08-07-2009, 04:52 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
No. Buy the correct wire.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 08-07-2009, 05:11 PM   #3
Registered User
Termite's Avatar
Agreed.
Old 08-07-2009, 06:40 PM   #4
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Have some extra #10 layin around and not enough #8 or is this a technical question?
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-08-2009, 11:50 AM   #5
Rewards Points: 60
No. The smallest wire that can be paralleled is a 1/0. So #10 in parallel would be a code violation. This would be a technical answer.
J. V. is online now   Reply With Quote
Old 08-08-2009, 11:52 AM   #6
Rewards Points: 2,350
I'm curious what the title of this thread has to do with the subject?
Old 08-08-2009, 12:31 PM   #7
Practically, no, because of unequal current sharing caused by unequal and unpredictable contact impedance at the connections.
Twisting two bare conductors together over their whole length may work. Using 4 or 8 #10s in parallel may also give you something workable [that still violates code].
What distance are you running over?
Old 08-08-2009, 12:32 PM   #8
Electrical Contractor
kbsparky's Avatar
What is the rating on your A/C compressor?
It may be possible that you only need one set of the #10 wires to do the job.
-KB
Old 08-08-2009, 01:52 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
I gotta agree with KB on this one. It's a pretty serious ac compressor that takes a #8 branch circuit but it's certainly possible.
Stubbie
Old 08-08-2009, 09:50 PM   #10
Mine is wired with #8 on a 40 amp breaker. It's a 230v 5hp emglo 80 gal tank. I believe the fla on the motor is 23 or 27 amps, I don't remember.
Plumbvoltage is offline   Reply With Quote
Old 08-08-2009, 11:18 PM   #11
kbsparky's Avatar
Plumb, we are dealing with an A/C compressor here, not an air compressor.
But to respond to your statistics, your installation should work just fine using a #10 wire on that 40 Amp breaker.
-KB
Old 08-09-2009, 02:50 PM   #12
Rewards Points: 60
I bet he means "Air Compressor". AC for voltage. DIY talk.
Old 08-09-2009, 05:11 PM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Obviously the OP either does not care, or did not like the answers. Either way he has not even checked in for over two days since he made this post.
Don't 'cha love when folks do that.
At least have the courtesy to come back and say thanks.
Old 08-09-2009, 09:31 PM   #14
Advice worth 2 cents!
Rewards Points: 150
Hey Speedy, I think the OP is probably just another arrogant engineer who thinks he knows everything but wanted to check with the "Pro's" in the real world. I work with these kinda of folks all the time.
Glad to see your still on the ball...Happy Summer!
____pete
---pete
HandyPete is offline   Reply With Quote
Old 08-11-2009, 02:29 PM   #15
Rewards Points: 60
Speedy. Glad to see you brought this up. How many times must we type a response only to realize the OP has abandoned the thread?
Structural Engineer - Arlington, TX (DFW) CZSteve Building & Construction 1 04-21-2009 12:09 AM
Retired in the Land of Nuts Itchy Brother Introductions 1 02-26-2009 12:01 AM
engineer or architect? jersey joe Building & Construction 1 11-09-2008 02:25 PM
Upgrading Grounding System sweaty Electrical 28 08-18-2008 05:15 AM
