Resses Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 12-01-2010, 05:57 PM   #1
resses lighting
i have a 20x20 bed room,can i install 6 resses lights 65 watt bulb using 14/2 wire,will it be too much of a load? and do i have to use 2 dimmers?
chuckusaf is offline   Reply With Quote
Old 12-01-2010, 06:03 PM   #2
Electrician
What do you plan on doing to feed these lights? Are you running a new circuit or using an old one?
Chances are you will be fine either way.
The only time you would need 2 dimmers is if A) You want to be able to control some lights differently than others and B) if you have two separate circuits.
VersaBar is offline   Reply With Quote
Old 12-01-2010, 06:40 PM   #3
Rewards Points: 1,596
14 g good for 15 amps; your 6 lights are 3.3 amps so no problem with wire. Other issues answered by Versabar.
bob22 is offline   Reply With Quote
Lighting Options for a dropped ceiling basement markronz Electrical 11 04-20-2010 02:20 PM
Basement Lighting blaze01 Electrical 1 02-16-2010 11:24 AM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 12:25 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
