Resources For A Novice - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2008, 08:52 PM   #1
Learning by Doing
Leah Frances's Avatar
Resources for a novice
Cheers - I am undertaking a thorough and careful remodel of my 1800s home, including updating the electrical system. It ranges from properly grounded romex installed in the 1990s to hybrids of romex and K&T to other scary stuff I don't even know how to describe.
I am looking for some solid resources to educate myself about wiring.
Any Advice on Books? Websites? Tools I shouldn't try working without (I have already used my new Christmas gift, a Santronics AC sensor, to avoid problems during demolition).
Right now I know enough to know I need to learn more; and I have the time and the inclination to learn how to do it correctly.
LFW
I have been reading the forums, not a bad place to start, thanks for the help.
Leah Frances is offline   Reply With Quote
Old 01-15-2008, 09:09 PM   #2
Rewards Points: 150
Read some basic books to get an understanding, then (if you have the connections) walk a job site with an electrician and buy an hour or two of their time. I did this a long time ago and that provided me enough knowledge to ask better questions.
steve1234 is offline   Reply With Quote
Old 01-16-2008, 12:06 AM   #3
Rewards Points: 1,418
The large 8-1/2 x 11 paperback with a title like "how to do wiring" sold at Home Depot and similar stores is a good starter.
But you will need to know your way around the National Electric Code book to avoid getting into situations that will fail inspection. Examples: too many wire ends entering a box of a given size, and not having the required wire size for the line going to, say, the bathroom (12 gauge here) and sharing the same circuit such as the kitchen counter appliance circuit that should not be shared with other rooms' receptacles.
Old 01-16-2008, 01:41 AM   #4
Find a book that will teach you how to earn extra money and use it to hire a good electrician.
220/221 is offline   Reply With Quote
Old 01-16-2008, 03:32 PM   #5
Look for a book called Your Old Wiring by David Shapiro.
There's an electrical safety manual online at http://www.cdc.gov/niosh/pdfs/02-123.pdf.
Fluke has some useful application notes at http://us.fluke.com/usen/support/appnotes/default?category=AP_ALL(FlukeProducts)&parent=APP_ NOTES(FlukeProducts)#
Look for "Diagnosing Power Problems at the Receptacle."
The NEC is available for free online viewing (but you can't copy or print it) at the NFPA website. The 2005 NEC is at this link: http://www.nfpa.org/freecodes/free_a....asp?id=7005SB
The 2008 edition is at this link:
http://www.nfpa.org/freecodes/free_a....asp?id=7008SB
You'll have to check with your local AHJ to see which version is in effect in your area and what local amendments they have adopted.
Matsukaze is offline   Reply With Quote
Old 01-16-2008, 05:40 PM   #6
Licensed Pro
"Wiring a House" by Rex Cauldwell
"Electrical Wiring, Residential" by Mullin
Old 01-16-2008, 07:23 PM   #7
"Call an Electrician" by Willet Burn
Novice question: Installing windows in wood sided home...(pic) Dr. Jim Building & Construction 5 07-06-2007 07:33 PM
Electronics NOVICE nailfun Electrical 7 03-02-2007 05:59 AM
Finding DIY HVAC Resources askme233 HVAC 18 12-28-2006 09:54 AM
Novice: Painting lighter colour over darker psd99 Painting 5 01-18-2006 09:24 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
