Old 04-16-2012, 09:39 AM   #16
I=E/R
a7ecorsair's Avatar
Resistor/Led and Basic Electricity Questions
From my understanding here we don't need a resistor because since our power supply only deliver 1.8V, there is no way the LED would draw more than her normal voltage, and no higher voltage means no higher current so the current it will received will be a little less than its specification here and then the light output will be a little dimmer. Or am I wrong and the LED will drawn 1.8V and will be hit by the 500mA and die right away ?
The LED doesn't "draw" voltage from the power supply. In this example, the LED will never be forward biased because the power supply output is too low and therefore the LED will not allow any current flow.
Let's assume you have a variable output power supply that goes from 1 volt to 3 volts and can deliver 500 ma of current.
Hook your 20 ma rated LED up to this PS and start adjusting the voltage upward. There will be no current flow until the LED forward biases. At 2 volts the LED will forward bias and burn up because there will be 500 ma flowing through it.
a7ecorsair is offline   Reply With Quote
Old 04-16-2012, 12:18 PM   #17
Thanks I understand
I need a small precision in a similar matter but with a different power supply. If I take 2 LR6 1.5V 2600mah battery and hook them up and take a 3V LED 20mA, in this case the LED will be forward biased but what current will it get and will it work ?
Khivar is offline   Reply With Quote
Old 04-16-2012, 01:01 PM   #18
Semi-Pro Electro-Geek
Originally Posted by joed View Post
It is designed to be used on a 2 volt supply. A true bare LED has a voltage of .7 volts. This one has been designed for 2 volts. They also make them for other voltage. I have used the 12 volt ones often. They don't need any resistors.
Now if you want to use the 2 volt LED on a different voltage than 2 volts then a resistor is going to be needed.
Typical LED's have operating voltages from about 1.8 to 3.5V. Voltage is determined directly by the color of the LED. See my earlier post on this, or the wikipedia article on LED's for a decent explanation. A 0.7V LED would be very dark red or infrared and is unusual. A 2V LED would probably be green.
All LED's have a specified operating voltage (discussed in detail in my earlier post), but this does not mean they are intended to be used with a constant voltage supply and thus don't require a resistor. Here's an LED data sheet for a green LED with a rated Vf of 2.1V for example: http://media.digikey.com/pdf/Data%20...ST-C191GKT.pdf
mpoulton is offline   Reply With Quote
Old 04-16-2012, 03:27 PM   #19
I=E/R
a7ecorsair's Avatar
Originally Posted by Khivar View Post
Thanks I understand
Get yourself a variable resistor to work with and use a 12V power supply. Using a 3V supply to illuminate a 3V LED is a poor design.
Old 04-16-2012, 07:15 PM   #20
You can make a solid state series resistor that will act as a constant current source using an LM117 voltage regulator and a resistor. For 20mA select R to be approximately 62 Ohms. 56 Ohms is a standard value and that will yield 22mA across a widely varying input voltage up to 30 volts. That might take some of the guess work out of it.
curiousB is offline   Reply With Quote
The Following User Says Thank You to curiousB For This Useful Post:
mpoulton (04-17-2012)
Some basic roofing questions tibberous Roofing/Siding 4 03-20-2012 05:49 PM
Basic (hopefully) electrical questions k2000lbs Electrical 10 04-27-2011 01:59 PM
Basic Bathroom Remodel Questions kwilliams512 Remodeling 0 02-26-2010 01:35 PM
Several basic questions re: outdoor floodlight install zinla Electrical 8 09-17-2009 11:39 PM
Basic questions... brackh HVAC 1 04-10-2008 07:02 AM
