Residential Wire Troughs. - Electrical - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 04:34 PM   #1
Residential wire troughs.
I'm working on rewiring my 1950's home.
I have most of it done and now working on the kitchen and utility room. The kitchen is over the utility room and with the amount of wiring that is needed it would be nice to use a wire trough or a sub panel.
Between the 2 rooms I will need 9 20amp, 2 30amp, and a 50amp.
I don't mind drilling the joist, but I would need to drill 65 of them and then drill the 8 thick wooden beam.
I have thought about using 2 runs of 2 pvc, but you can not run romex in pvc pipe
I was thinking about using pvc guttering, but unsure how that would fly with protection from physical damage.
I know run the wiring between 2 peaces of wood attached to the joist, but I tried that and it looked bad.
Any sugestions?
1950home is offline   Reply With Quote
Old 09-14-2012, 04:40 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
http://www.aifittings.com/products/s...s/cableway.pdf
Old 09-14-2012, 04:56 PM   #3
yes that's what i need.
now to find it local on a Saturday.
Old 09-14-2012, 04:56 PM   #4
E2 Electrician
try an electrical supply house....
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
Proper Use of Green Wire Nuts HooKooDooKu Electrical 16 06-29-2012 06:41 PM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
