Residential Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 04:25 PM   #1
Recently my sister had a licensed electrician upgrade the electric service from 60 to 100 amps. When she called on me to reset a tripped breaker I noticed the box did not have a main breaker. The service wires are tied on to the buss bars at the top which feed the separate breakers. 15, 20, 30 amps. I have never seen this before and was wondering if this is up to code? A permit was taken and I presume it was inspected. thanks, Bob
Rbates1944 is offline   Reply With Quote
Old 07-09-2012, 04:26 PM   #2
Sparky
Rewards Points: 510
if there is no main disconnect ahead of this(assuming main/only panel), and more than 6 throws of the hand to disconnect all power, yes this is a code violation
Techy is offline   Reply With Quote
Old 07-09-2012, 04:39 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Did it pass inspection? Did you look outside for a disconnect?
Old 07-09-2012, 05:21 PM   #4
joed's Avatar
Rewards Points: 12,426
Go look at the meter. Is there a breaker there?
Old 07-09-2012, 09:43 PM   #5
Thanks everyone. I'll check these things out tomorrow. Bob
Old 07-10-2012, 07:29 AM   #6
Rewards Points: 3,130
What you are seeing is a main lug only (MLO) panel. They are quite common; the panel in my house is an MLO. The main disconnect is outside, next to the meter. I do not know the specific requirement, but there is a maximum distance the panel can be away from the meter before you have to have a disconnect at the meter. I think it's something like 5 feet.
Old 07-10-2012, 07:41 AM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
That distance varies greatly depending on where you live.
Old 07-10-2012, 08:28 AM   #8
Yes, I imagine it does. Just like many things in the code.
Old 07-10-2012, 04:49 PM   #9
E2 Electrician
The actual code states this; The service disconnecting means shall be readily accessible location either outside of a building or structure or inside nearest the point of entrance of the service conductors.
Now, with that said, why an inspector would allow anything but the nearest point of entrance I have no clue.
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
200 amp breaker in a 100 amp service panel? CalMag Electrical 5 09-12-2010 08:00 PM
service panel wires douglascase Electrical 3 06-12-2010 03:28 PM
200 amp panel w/100 amp service PirateKatz Electrical 8 12-26-2009 03:42 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
