Residential Power Drainage? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-23-2007, 08:37 AM   #1
After troubleshooting a problem with my HVAC, I found that a phase leg of my whole residential service was dead. I informed the power company, and they installed a new underground service line. I've just noticed that this seems to have also resolved another problem I had been having for quite some time now:
We have had a slight dimming of certain lights when using, say, the HVAC, microwave, or a coffee pot etc. At this point, this seems to have disappeared as a by-product of having the new service lines installed. This leads me to the following question:
Is it possible with two-phase AC power, that our seemingly very high electric bill has been caused by a 'drainage' of power.
Is it possible that we were draining power by a 'nick', in one line of the underground service, without it actually shorting out until last week ???
thanks
travlr is offline   Reply With Quote
Old 09-23-2007, 09:08 AM   #2
Master Electrician
JohnJ0906's Avatar
This "nick" was before the meter, correct? If so, I don't see how this would affect the amount you are charged.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 09-23-2007, 09:27 AM   #3
Yeah. Kind of 'doh!' moment for me just now. I'd better go get another cup of coffee.
thanks John
Old 09-23-2007, 09:39 AM   #4
Master Electrician
JohnJ0906's Avatar
Has the amount of kilowatt-hours you are using change recently?
If you are questioning your bill, check to see if your usage changed.
Also check if your rates changed. (Ours just jumped 50% )
John from Baltimore
One Day at a Time
Old 09-23-2007, 09:43 AM   #5
Well I'm going to have to pay attention and compare the past from here ..forward.
Old 10-03-2007, 09:15 AM   #6
Power Drainage Revisited
It turns out that the aging underground service to my house, did in fact have an open ground for quite some time ( a year or two).
It's my understanding that in these situations, on a two phase system, a load put on one leg will cause a the voltage coming through the meter to weaken. A load put on the other leg will cause the the voltage to strengthen (a steady surge).
This was demonstrated to me by the power company's service-man though a load test at the meter. I forgot to ask the service-man the following question:
If, possibly, most of the load from my house comes from the phase that increases in voltage, isn't it possible that I have been paying more for power than I should should have been?
thanks,
Old 10-03-2007, 11:41 AM   #7
Once fried, twice shy.
elkangorito's Avatar
Assuming the USA is using electromechanical or electronic kiloWatt hour meters, your electric bill will not be incorrect. These meters calculate power usage against voltage & current.
Switchboard design engineer & Licensed Electrician (Australia).
elkangorito is offline   Reply With Quote
power line noise sciguy125 Electrical 5 12-02-2007 02:39 PM
Power going out but not tripping breaker toddforpres Electrical 9 09-07-2007 04:11 PM
distribute power Mayhem_Hobbies Electrical 8 01-17-2007 10:03 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
