-   -   Residential Power Drainage? (http://www.diychatroom.com/f18/residential-power-drainage-11765/)
travlr 09-23-2007 08:37 AM
After troubleshooting a problem with my HVAC, I found that a phase leg of my whole residential service was dead. I informed the power company, and they installed a new underground service line. I've just noticed that this seems to have also resolved another problem I had been having for quite some time now:
We have had a slight dimming of certain lights when using, say, the HVAC, microwave, or a coffee pot etc. At this point, this seems to have disappeared as a by-product of having the new service lines installed. This leads me to the following question:
Is it possible with two-phase AC power, that our seemingly very high electric bill has been caused by a 'drainage' of power.
Is it possible that we were draining power by a 'nick', in one line of the underground service, without it actually shorting out until last week ???
thanks
JohnJ0906 09-23-2007 09:08 AM
This "nick" was before the meter, correct? If so, I don't see how this would affect the amount you are charged.
travlr 09-23-2007 09:27 AM
Yeah. Kind of 'doh!' moment for me just now. I'd better go get another cup of coffee.
thanks John
JohnJ0906 09-23-2007 09:39 AM
Has the amount of kilowatt-hours you are using change recently?
If you are questioning your bill, check to see if your usage changed.
Also check if your rates changed. (Ours just jumped 50% :censored: )
travlr 09-23-2007 09:43 AM
Well I'm going to have to pay attention and compare the past from here ..forward.
travlr 10-03-2007 09:15 AM
Power Drainage Revisited
It turns out that the aging underground service to my house, did in fact have an open ground for quite some time ( a year or two).
It's my understanding that in these situations, on a two phase system, a load put on one leg will cause a the voltage coming through the meter to weaken. A load put on the other leg will cause the the voltage to strengthen (a steady surge).
This was demonstrated to me by the power company's service-man though a load test at the meter. I forgot to ask the service-man the following question:
If, possibly, most of the load from my house comes from the phase that increases in voltage, isn't it possible that I have been paying more for power than I should should have been?
thanks,
elkangorito 10-03-2007 11:41 AM
Assuming the USA is using electromechanical or electronic kiloWatt hour meters, your electric bill will not be incorrect. These meters calculate power usage against voltage & current.
