Residential Electrical Panel Load. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-08-2012, 11:41 PM   #1
Hi,
My house has main electric panel provisioned with total 200 Amps circuit breakers (100 Amps each) on the main line, i.e., electric panel is of 200 Amps capacity. Please advise me how many circuit breakers can I install on the pannel (as for as there is physical provision on the panel) for different circuits in the home in terms of the total current capacity of all the combined circuit breakers for all the home circuits, e.g., 40+40 Amps circuit breaker for Range, 30+30 Amps circuit breaker for Dryer, 20 Amps circuit breaker for Kitchen etc.
Thanks,
Irshad
Irshad is offline   Reply With Quote
Old 02-09-2012, 12:20 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Irshad View Post
Hi,
Thanks,
Irshad
Let me clear this up for ya due you say 100 amp each on the main breaker it do NOT add the numbers at all so they are at 100 amp each leg or phase so you do not have 200 amp capacity at all unless you look at the model number on the cover door or in the breaker panel you will have to find the label for it.
Second thing is that if you have 40+40 it is not addtive as well it is a 40 amp two pole breaker ditto for dryer it will be 30 amp two pole breaker and single pole if you see only one set of numbers that is single pole.
This is a two pole breaker.,
Now this is a single pole breaker
Now that should clear up what you try to do this.
Merci,
Marc
Old 02-09-2012, 03:51 AM   #3
Julius793's Avatar
Being that there's a main breaker you can put in as many breakers as the panel can hold.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
plummen (02-09-2012)
Old 02-09-2012, 07:00 AM   #4
Rewards Points: 6,652
You could install a thousand breakers, that will not make the difference. What will, is the number of items that will place a load on the panel. What that means is, is there an electric stove, electric dryer, electric furnace, heat pump, welder in the garage, large size air compressor, a lot of high intensity flood lights outside. Plan on running a grow-op.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 02-09-2012, 07:13 AM   #5
Licensed electrician
Rewards Points: 1,870
The important thing to pay attention to is how many the label says you can install.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
NJMarine (02-11-2012), plummen (02-09-2012), zappa (02-09-2012)
Old 02-09-2012, 08:46 AM   #6
Rewards Points: 764
And what the load calculation says you can install.
Mark
busman is offline   Reply With Quote
Old 02-09-2012, 09:12 AM   #7
Julius793's Avatar
Mark
No load calculation is completely irrelevant if there's a main.
Old 02-09-2012, 09:30 AM   #8
Why is that?
M Engineer is offline   Reply With Quote
Old 02-09-2012, 09:45 AM   #9
Julius793's Avatar
Originally Posted by M Engineer
Why is that?
Assuming you read the post: if you were to add up the amperages of the breakers in a typical panel you will find that most will be a few times the amperage of the main. Which is not an issue at all because as soon as the main is overloaded it will trip. However if we were to be discussing a split bus panel, then the top would require a load calculation.
The Following 2 Users Say Thank You to Julius793 For This Useful Post:
plummen (02-09-2012), Yoyizit (02-09-2012)
Old 02-09-2012, 10:27 AM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Mark
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-09-2012, 11:08 AM   #11
. . .a split bus panel. . .
http://www.google.com/imgres?imgurl=...9QEwAg&dur=187
While we're on the subject, can someone please post some resi. single phase panel schematics? Figuring it out with a meter can be confusing and dangerous.
There can't be too many of them. . .right???
Old 02-09-2012, 12:01 PM   #12
Seems like to me it would be an issue if the main is tripping all the time.
Old 02-09-2012, 12:04 PM   #13
Julius793's Avatar
Well if you think it's an issue than you clearly aren't an electrician.
Old 02-09-2012, 12:10 PM   #14
Rewards Points: 764
All new services and additions to services require a load calculation. Just because there is a circuit breaker doesn't mean it's OK to just fill up the panel until the main trips. It's there as a secondary protection method. The load calculation provides a very low likelihood of the main ever needing to trip.
Mark
Old 02-09-2012, 12:13 PM   #15
No. I am not an electrician. Would you please explain why a load calculation is not necessary?
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Miswire for 240V and electrical panel replacment? daluu Electrical 21 01-26-2012 04:17 AM
Sub Panel GND and mixed 240/120 VAC branch curiousB Electrical 12 01-17-2012 10:49 AM
Sub Panel Main Lug Load Center - Single Phase ? Roy Rowlett Electrical 21 08-20-2009 06:55 PM
