Residential Electrical Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-14-2005, 02:02 PM   #1
residential electrical installation
I Have An Electrical Box I Would Like To Install (2) Switches In. The Box Has 3-white , 3 Black And Three Grounds Conbined In To Single Ground Wire. I Want To Install Two Switches Side By Side. I Have Checked The Wires As Instructed To Check For Power , However , None Of The Wires Appear Alive. Any Help?
Dallas520
dallas520 is offline   Reply With Quote
Old 05-15-2005, 08:51 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Telling us what you intend to do is a good start.
What are you trying to switch?
Is this a two gang box?
If there is no power on any of the wires then you need to find out why. There is probably a bad connection upstream of this box. Unless you are capable and willing to start opening up boxes and checking connections this might be a good time to call in an electrician.
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Home Electrical / Car Stereo Question pjpjpjpj Electrical 4 08-12-2012 06:59 PM
dishwasher electrical wire feb Electrical 31 04-12-2008 10:04 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Residential Electrical Ground David TG Electrical 1 05-07-2005 04:02 PM
