Resi breakers, testing of
Questions to a CB manuf.:
Is there a recommended replacement interval for resi. CBs? Is there any problem with periodically testing them by loading them to 2x or 3x rated current, measuring trip time and then comparing this value to the trip curve? A: There are no recommended time frames to replace residential breakers, as far as testing we test per UL 489, there is no additional field testing required, however if you want to periodically test the overload there is no problem doing so. |
UL does not deal with field tests. UL tests are lab testings.
as to UL not limiting field tests: of course not, That is not what they do but I do know that some, if not all manufacturers recommend 2 things with breakers: they are exercised regularly (simply switched on and off several times) to prevent them from becoming stiff if they are exposed to a ground fault trip (magnetic trip), it is recommended they be replaced. While I suspect it is mainly as a defense to a liability claim, in all reality, a breaker can be exposed to possibly thousands of amps any time there is such an overload and that amount of current can cause unseen damage. ------------------------------- there is no design life I am aware of or ever been told of. As such, there is no recommended replacement interval I have ever heard of. Quote:
Most resdentail breakers as far as I know there really no life limit on them due there is a bit of variations what it will be used etc .,
But on very large commercal and Industrail breaker yeah there is the Numbers of cycles we have go thru before it will be either replace or rebuilt however if got very hevey bolt fault it pretty much automatic replacement for new breaker and megger that affected circuit for any hidden damage especailly that is true with 480 volts 60 HZ { 415 V 50 HZ as well } and above. However basically just exersice the breaker every year by turn it on and off I know you may hate to reset the clock and reboot the computer but that is the good safe way to make sure everything is up to the stuff. Merci. Marc |
I've known several commercial properties that used the breakers to turn the lights off & on every day
I guess that would exercise them...maybe too much ? Only about 700 flips a year |
Dave.,
Not really if the breaker have "SWD " stamped on the handle they are designed as switching load and they last little longer than standard breaker they are useally found in 15 or 20 amp single pole breaker { either 120 or 277 volts verison } IIRC I think they can take up to 10,000 cycles but there are few other type of breakers most will not be listed in the redentstail side. Merci. Marc |
Check out this discussion of breaker testing.
http://www.terrylove.com/forums/show...ease&highlight= |
I always wondered if this guy was that guy!!!!!!!!!!
I was still trying to figure out how placing a 50 amp breaker in series with a 15 amp breaker would tell you the trip level or is the breaker was good. After all it is just a switch, there is no load with the larger breaker. And why would you need an LED, couldn't you see the tripped breaker? Along with how you test a breaker under no load conditions. Quote:
1. I plagiarized his stuff or 2. We have the same ghost writer or 3. I was the kid in the avatar or 4. I was the snake in the avatar You're good, Mr. Fan. http://en.wikipedia.org/wiki/Jimmy_Buffett BTW, that Marne guy wasn't the most obnoxious, condescending turkey that I ever met in my whole long and miserable life, but he was sure up there! I hope Cookie is doing better. I always felt bad for that lady. |
Jim, Check the link you posted and see who started that thread on terry loves site.
| All times are GMT -4. The time now is 01:19 PM. |
