Requirements For An Island Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 01:52 PM   #1
requirements for an island wiring
is the wiring requirements the same for an island as it is for counters, (20a or 15a split two per circuit) also is there any rules about where the placement of the recs should be (ie can i surface mount them on the island couinter
brit in canada is offline   Reply With Quote
Old 12-12-2010, 04:31 PM   #2
Electrician
Rewards Points: 802
I assume your in Canada by your name.
The code says at least one recepticale(15A split or 20A) installed at each permanently fixed island counter space with a long dimension of 600mm or greater and a short dimension of 300mm or greater.
I'm not sure how to interpet that, maybe one of the other Canadians on here who do residential will be able to fill us in.
The plugs can not be surfaced mounter, I would say put them on the side and try to cut them into the cabinet for they look good.
darren is offline   Reply With Quote
Old 12-12-2010, 04:42 PM   #3
joed's Avatar
Rewards Points: 13,712
Plugs can not be mounted face up in the counter. They can be surface mounted if you use a tombstone.
Here is a sample picture.
Old 12-13-2010, 02:52 PM   #4
thanks guys, the tombstone idea is a good one Joed
Difference between 220 and 240 volt requirements? cleveland Electrical 7 04-14-2010 07:24 AM
electrical requirements for large whole home system jumonji Electrical 6 02-23-2010 01:41 AM
Code requirements for low voltage wiring in conduit with 120V flyboy Electrical 9 12-24-2009 06:48 PM
Requirements for Granite? jerome8283 Interior Decorating 2 01-02-2009 04:05 PM
Drain clean out requirements steve1234 Plumbing 2 11-20-2007 11:06 PM
