Required Support For Wiring In Walls? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-18-2007, 09:14 PM   #1
Required support for wiring in walls?
I'm finishing a basement and have used 2x3 studs around the exterior room walls. I've got a half inch gap between the stud walls and the concrete basement walls... is it okay to run NM electrical lines in this gap (to avoid drilling holes in the studs and make routing them easier)? I'm sure I still need to staple the wires every 4 feet or so and it will be awkward to do so for the horizontal runs but is there any general rule against doing this?
Thanks..
leonsphinx is offline   Reply With Quote
Old 02-19-2007, 02:32 AM   #2
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Leon
If this is your preference then tapcon some scrap 2x3 to the concrete wall inbetween studs at 4 feet intervals or there abouts. Staple your nm to the scrap. You must fasten it every 4 or 4 1/2 feet to satisfy most inspectors.
Personnally I would just drill the center of the studs and put a metal nail plate on the face of each stud where the cable passes through. One of these.......
Stubbie
Old 02-21-2007, 11:35 AM   #3
Electrical contractor
RobertWilber's Avatar
Perfectly OK to run behind the stud wall.
NEC 334.30 - Fasten every four and a half feet and within 12 inches of boxes. If you are running behind the studs, it is acceptable to use cable ties to secure the cable to the back of the stud.
RobertWilber is offline   Reply With Quote
Old 02-21-2007, 02:37 PM   #4
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
What RobertWilber said.
Just to add - I did this with some coax and cat 5. I put a staple every so many feet, right at the back edge of the stud,
I then used wire ties to support the wire. Easy as pie.
Brik is offline   Reply With Quote
Old 02-22-2007, 11:56 PM   #5
Thanks guys... I'll try it and see how my inspections go.
Old 02-23-2007, 07:25 AM   #6
RippySkippy's Avatar
You could always call your inspector and ask them...may save you a load of time up front. I do this all the time with my house building project...don't know, call and ask...most times I'm right, other times I was glad to have his input.
RIp
RippySkippy is offline   Reply With Quote
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 09:26 AM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
bowing walls - repair? elementx440 Building & Construction 26 03-04-2009 04:07 PM
IRC 404 Basement walls lateral support? bjr23 Building & Construction 2 07-26-2007 10:07 AM
Need help with basement support jaw522 Building & Construction 3 10-25-2006 09:55 AM
