Replacing A Wall Outlet Dimmer Switch With A Rocker Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2010, 09:35 AM   #1
Replacing a wall outlet dimmer switch with a rocker switch
I want to replace a touch pad dimmer switch with a rocker style switch, the dimmer controls two wall outlets and has a black,red and green wire, black is connected to black, red to the white and green is to the common wire. The rocker switch has 4 screw terminals one is for grounding the switch plate metal housing and one that is labled for the CU wire only. Would I hook the common wire to the one labled CU only and the black and white wires to the two remaning terminals?
Thank You,
Lonepine is offline   Reply With Quote
Old 01-05-2010, 11:18 AM   #2
Licensed Pro
Thank You,
There is no "common" wire. The green wire is for grounding only and should be connected to the grounding terminal. Assuming you only have one white and one black in the box, the white should be the constant hot (and should be remarked with black tape) and the black should be the switched hot back to the outlet. If your new switch has three terminals (plus the ground), it is a 3way switch and is incorrect for this application... you need a single pole switch with two terminals (plus ground).
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 12:43 PM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 11:30 PM
wiring a dedicated switch to a outlet Michel Electrical 2 09-18-2008 07:25 PM
Replacing Dimmer Switch dallas520 Electrical 3 05-15-2005 12:49 PM
Wall Switch sue Electrical 4 02-06-2005 08:05 PM
