Replacing wall light.
Apologize for lack of clarity and confusion of terms. To clarify:
"new one" is the new sconce, a hard-wire fixture replacing a different hard-wire fixture. It's just the receptacle where I am putting the actual hard-wired fixture and the switch that controls it. There are no outlets involved. The fixture just turned on/off by the switch.
The diagram attached/below from the first post has my wire sets in both locations, and here is a written version in case you can't see the attachment from before.
SWITCH BOX: -
If you did it "by set" with the switch totally removed it would be
Two sets:
set 1: white, black, red, bare
set 2: black, white, bare
[this part I haven't taken apart...its how it was]: 1 red (connected to the top of the switch); 2 white (coming out of different sides of the box and joined by a wirenut and not going to the switch -- just in and out of the box); 2 black (also coming out of different sides of the box and joined by a wirenut together to a third black wire that goes to the bottom screw of the switch)
RECEPTACLE
2 sets
set 2: white, black, bare
(the bare actually looks like it comes out of one set and into the other (no nuts))
(also because of the filthy nature of the box/wires, I am not 100% sure which of black and white is which)
My meter is a "no contact meter" which I realize was a poor choice now for this application, as it reads a current if anything within an inch or two is live, which makes it pretty useless for figuring out which wire in the box is live and which isnt.
