Replacing (Very) Old Garage Door Opener--is It 250v? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-27-2012, 11:26 AM   #1
Replacing (Very) old Garage door opener--is it 250v?
Hello everyone,
I am trying to replace a 40-year old garage door opener that stopped working, and the motor reads "250v"-- are 250 volt openers standard? does the 250v mean something completely different? or will I have to re-wire it to a standard 110v outlet type to put in a new opener? The original cover has most likely been lost to time; the brand was Overhead Door company.
I haven't purchased any new openers yet, making sure I know what I am getting into first :-)
The door is not especially large --9'x7' not sure of their weight; if it matters, the door will likely be replaced shortly as well.
Thanks for any and all help!
captainsparkle is offline   Reply With Quote
Old 04-27-2012, 11:31 AM   #2
Rewards Points: 1,580
How is it wired into power source? Plug look like a regular 110 v one?
bob22 is offline   Reply With Quote
Old 04-27-2012, 11:31 AM   #3
Rewards Points: 13,694
220 volt would be an odd ball. Sure it does not say 220/110?
How about a picture of the plug?
Figure out what breaker shuts it off. If it's a double breaker then most likyl it is 220 volts.
You could also check it with a meter.
Old 04-27-2012, 11:47 AM   #4
joed's Avatar
Rewards Points: 12,850
Home door openers are normally 120 volt even 40 years ago. Could be that someone got a commercial one that was 240 volt.
Old 04-27-2012, 11:51 AM   #5
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Get a voltage tester and check the voltages at the receptacle or wires that feed the old garage door opener. That will tell you what voltage you have and if you need to make any changes to accommodate the new 120v GDO.
JulieMor is offline   Reply With Quote
Old 04-27-2012, 12:05 PM   #6
Thanks for all the quick help!
I feel kind of stupid not taking a closer look at all these things;
Regular outlet, controlled by a regular 15a breaker
while the outside of the motor is definitely stamped 250V, I now think that is just a manufacturer number;
there is a sticker identifying the motor (which I did not see previously) clearly states that the motor is Westinghouse 1/3HP, 115v, 3.6a, 1000RPM motor.
It is probably worth testing to be certain (since that is just the motor, not the outlet nor the device), but it alleviates most of the fears that I had.
Thanks again; I realize that I have only made the one post, but of all of the internet communities I have been involved with, this one is definitely one of the most thoughtful and helpful!
Old 04-27-2012, 06:00 PM   #7
Ravenworks's Avatar
Stick around,there are no stupid questions
Ravenworks is offline   Reply With Quote
Tags
garage door opener
unconditioned garage reillyoevans HVAC 3 08-20-2011 06:29 PM
Replacing windows with a full-view garage door all1knew Windows and Doors 11 07-27-2011 01:47 PM
Garage floor Tomperro Building & Construction 3 07-17-2011 11:37 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Replacing Wall in Garage viking1974 Building & Construction 3 08-10-2007 10:23 PM
