-   -   Replacing two switches on one plate, each wired to a different breaker. (http://www.diychatroom.com/f18/replacing-two-switches-one-plate-each-wired-different-breaker-119737/)
bcainjr78 10-10-2011 06:31 PM
I'm trying to replace two switches (one above the other on the same box, sideways, like an equals sign); each of these switches is wired to a different breaker. When I went to hook up the new switches, one of the lights works, and the other won't. Not only does it not work, but when I try to turn it on, it cuts out the other light (from the other switch.
HELP!
a7ecorsair 10-10-2011 07:31 PM
Are these two separate switches or are they two switches on one yoke or strap? You didn't make a diagram before you unhooked wires, did you:huh:
bcainjr78 10-10-2011 10:05 PM
Two switches on one yoke; I didn't make a diagram, but I know which sides each wire came from, so there are only 4 different possibilities, all of which I've tried.
I got the one light to work, but the other one just doesn't want to work. I just bought this house, and I've learned that there are 12 active breakers for the entire house...probably 36 outlets. I can't plug in my laptop and turn on a light without tripping a breaker!
gregzoll 10-10-2011 10:26 PM
How old is the house, and before you bought the home, how detailed was the home inspector, in the aspect of electrical, mechanicals (hvac), and plumbing? Did they note the age of the electrical system in the home, and possible problems. All of this would have been in the documents they would have provided you before you signed off on the sale.
Post pictures of the breaker or fuse panel (make sure that the picture is sized, so it shows the whole panel, same for the junction box), and the junction box in question. What you may have, is a bunch of MWBC (multi wire branch circuits), that means they would share a neutral and ground, but you would have two hots coming in.
As for blowing fuses or tripping breakers, it depends on how much load is on a circuit, not how many circuits are in the home. If you are tripping the main breaker, then yes there would be a problem, that the system is outdated and can not handle modern conveniences.
SD515 10-11-2011 07:23 AM
Did you break off the jumper tab on the side of the switch?
