Replacing Thermostat For Electric Baseboard Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 01-06-2014, 02:53 PM   #1
replacing thermostat for electric baseboard heat
Hi everyone,
I am replacing an old White Rogers thermostat to a newer 2 pole Honeywell for electric baseboard heating only in a condo. From the wall, there is a red wire, a white wire, and 2 black wires connected to each other. Can someone advise if it is correct to connect the wall red to R1, and the white to T1 on the 2 pole, with leaving the black wires as is? Also, with only using the one side, would I need to cap the R2 and T2 or can they be left as they were when packaged?
Thank you for your help,
Derek
derekDIY is offline   Reply With Quote
Tags
electric baseboard heat , thermostat replacement , wiring
Replacing thermostat for baseboard heaters Bchavez Electrical 6 12-16-2012 09:49 AM
New Trane Heat Pump Thermostat cory_booth HVAC 0 08-30-2012 09:44 AM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 09:22 PM
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
