Replacing T5 HO Tubes With HE - Electrical - DIY Chatroom Home Improvement Forum
Old 07-26-2012, 07:33 PM   #1
Replacing T5 HO tubes with HE
Hi,
Just bought a T5 aquarium light with HO tubes, for some reason this new T5 HO light is not as bright as the old T5 HE light, wanting to make the best of this new light, is it possible for me to replace the T5 HO tubes in the new light with T5 HE tubes, without the risk of burning my house down? I have very little electrical knowledge, so forgive me if this is a dumb question.
BornYesterday is offline   Reply With Quote
Old 07-26-2012, 08:53 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by BornYesterday
Hi,
You have to go off the ballast, check that and see if it's compatible....
Old 07-26-2012, 09:02 PM   #3
Ballast is for 39w high output
Hi Stickboy,
The ballast is 39w and the tubes currently fixed to the light is also 39W HO, can I replace these tubes with 21W HE tubes.
Old 07-26-2012, 09:23 PM   #4
E2 Electrician
Originally Posted by BornYesterday View Post
Hi Stickboy,
The ballast will list every compatible lamp. If unsure, call the ballast manufacture.
Old 07-26-2012, 09:30 PM   #5
Missouri Bound's Avatar
Hi Stickboy,
Nope. The HE are specific for electronic ballasts with compatable wattages. You will overdrive the lamps and either burn them or the ballast out. If you must have the HE's you will need to change the ballast.
Do you want it your way or the right way?
Old 07-26-2012, 09:32 PM   #6
E2 Electrician
I did a little research and came to the same conclusion, but with so much changing technology, I didnt want to assume anything.
Old 07-26-2012, 09:36 PM   #7
I hear ya. I've been working with lamps and ballasts for about 30 years and it is constantly changing. It's like albums to 8 track to cassette to cd's and now digital.
Old 07-26-2012, 09:38 PM   #8
E2 Electrician
I've only used T5 lamps a few times, and we only install fluorescents in closets. More on the MR16 and low voltage side of the lighting spectrum.
Old 07-26-2012, 10:01 PM   #9
Thanks StickBoy and Missouri Bound
Hi StickBoy and Missouri Bound
Thanks for all your help, will look into replacing the ballasts, are they expensive? The light costed me $170.
Old 07-27-2012, 06:32 AM   #10
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Fluorescent lights take a while to burn in. Give them a week or so, and they will be brighter than the day you installed them.
Old 07-27-2012, 09:06 PM   #11
Had it for over a week now, will wait for another week to see if it improve.
Thank
Old 07-27-2012, 09:08 PM   #12
E2 Electrician
Is it true or not to initially leave them on for awhile to burn in?
Three tubes on drinking water faucet Cinci-Hal Plumbing 6 01-02-2012 02:35 PM
Flourescsent Tubes Dying Mystery wallix Electrical 14 08-24-2011 01:51 AM
Replacing Windows? Kyle Remodeling 13 12-17-2009 08:03 PM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 09:50 AM
Replacing windows in a Bedford Stone home tim_the_toolman Building & Construction 6 12-02-2008 08:27 AM
