Old 06-04-2012, 04:37 PM   #1
Replacing switches
Just need a quick opinion. I have three switches controlling one set of lights in a home theater setup. I want to use lutron replacements that are infrared remote controlled. One would be a main dimmer, while the other two are companion dimmers. I would like to do this myself. Is there much to it? Would I know immediately if something wasn't wired appropriately or could there be a danger or problem down the road? Thanks in advance for any replies!
tbbuhner is offline   Reply With Quote
Old 06-04-2012, 04:41 PM   #2
A "Handy Husband"
rjniles's Avatar
Replacing switches
Those dimmers require a neutral connection in the switch box. Make sure you have a neutral available before you buy.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
mart6992 (06-04-2012)
Old 06-04-2012, 05:01 PM   #3
Replacing switches
Why IR?
What remote control system are you using?
ktkelly is offline   Reply With Quote
Old 06-04-2012, 05:11 PM   #4
Replacing switches
Logitech Harmony One. I don't believe it does RF. And not sure about the neutrals. I have checked the instructions, and it looks like I have all the wires the instructions reference. Basically on the 4 way switch, there are two reds attaching to two different color screws and two blacks attached to two different color screws. It says to tag two of the same color wires that attach to different color screws and attach them to the blue screw. There seems to be enough wires there.
Old 06-04-2012, 06:18 PM   #5
A "Handy Husband"
rjniles's Avatar
Replacing switches
If you do not have a bundle of white wires connected together but not to the switch, you do not have a neutral. And these switches will not work.
Old 06-04-2012, 06:45 PM   #6
Replacing switches
I do have white wires in each box, but they do not connect to any of the three switches that I can see - although it looks like one attaches to the switch next to the one I'm replacing. And these whites do not get attached to any of the new switches as far as I can tell from instructions? So it seems I can proceed?
Old 06-04-2012, 07:26 PM   #7
Replacing switches
can't delete a post?
mart6992 is offline   Reply With Quote
Old 06-04-2012, 07:57 PM   #8
E2 Electrician
stickboy1375's Avatar
Replacing switches
What type of load are you dimming? Because I believe you DONT need a neutral connection for an Incandescent load... so it really depends on what you are dimming. You will only have to worry about having a neutral if you are dimming Electronic low voltage transformers....
Old 06-04-2012, 08:03 PM   #9
E2 Electrician
Replacing switches
I disagree/ only if dimming electronic low voltage transformers.
Old 06-04-2012, 08:51 PM   #10
Replacing switches
FWIW:
The Lutron dimmers that I've used DO require a neutral....
Old 06-04-2012, 08:55 PM   #11
E2 Electrician
Replacing switches
Originally Posted by ktkelly View Post
FWIW:
which ones?
Lets be specific here, because I already went to the website and verified which of the IR devices require one.
Here is the link by the way for the IR switches....
http://www.lutron.com/TechnicalDocum...30-864-03B.pdf
replacing 3 way switches steve57 Electrical 9 05-11-2010 03:23 PM
Question about switches on a 20 amp circuit Abs777 Electrical 6 04-28-2010 11:09 AM
Replacing switches turning into nightmare. RyanD Electrical 19 05-26-2009 07:19 PM
hooking up 3 way switches norcalsurfer1977 Electrical 16 04-28-2009 06:03 PM
replacing old lite switches yoeasy Electrical 5 12-04-2005 07:16 PM
