Replacing A Switch In A Mobile Home - Electrical - DIY Chatroom Home Improvement Forum
Old 09-01-2013, 11:20 AM   #1
replacing a switch in a mobile home
I have an electrical switch that operates an overhead light in my kitchen that went out. I removed the old switch, popped off the back cover, and surveyed the wiring scheme. All of the blacks were on one terminal, the white on another and the grounds on another. I twisted all of the blacks together, the whites together and the grounds together. The wall switch works, but when I touched the wires to the new over head switch the breaker kicked off. What am I doing wrong?
bill1951 is offline   Reply With Quote
Old 09-01-2013, 11:30 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
You have created a dead short. I'm pretty sure you saw the existing wiring incorrectly.
Old 09-01-2013, 11:33 AM   #3
I am in total agreement with you. Any thoughts on how to correct my error?
Old 09-01-2013, 11:36 AM   #4
k_buz's Avatar
You will need to find the wires that go to the fixture.
Old 09-01-2013, 11:40 AM   #5
I do appreciate your time. I have identified the incoming hot wire, and the wires for both lights. As of this minute, I have all of the blacks together, the whites together and the grounds. The wall light is working, but the overhead light is not. Again, if I touch the switch for the overhead light to the wires, the breaker will be thrown.
Old 09-01-2013, 11:51 AM   #6
How do you suggest I proceed?
Turn thermostat to COOL (mobile home split system), fuse on control board blows. justplumducky HVAC 8 04-29-2013 07:42 PM
Replacing Mobile Home Package AC Unit jack roscoe HVAC 3 05-24-2010 02:13 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 03:47 PM
Replacing light switch in series wired home - help! kellykate Electrical 6 04-16-2009 06:37 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
