Replacing Switch, Ground Wire Exist But Is Not Used - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 12:19 AM   #1
Lightbulb
replacing switch, ground wire exist but is not used
Hi, I hope this is a simple question. I am replacing a dimmer switch and when I pulled out the old switch I saw that the ground wire was not connected. There were two ground wires in the back of the box that were connected in a wire nut. When I put in the new switch I would like to ground it.
Question: Can I simply add the ground wire from the new switch to the two ground wires already in the nut?
Thanks!
keninnes is offline   Reply With Quote
Old 09-19-2012, 01:00 AM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Thanks!
Is the box your putting the new switch in metal?
If so,the grounds should be connected to the box.
You can then add a pig tail to the grounds you already have at the wire nut and connect it to the switch.
If the dimmer already has a ground coming of it ( green wire) just add it to the grounds already there.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
keninnes (09-19-2012)
Tags
dimmer switch , ground wire
Replacing Chandelier Ground Wire Question dreamstwogo Electrical 1 06-07-2012 01:24 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
switch lacking ground wire anervoustwitch Electrical 17 02-27-2009 04:12 PM
Replacing a single switch with 3 way switch using old wiring chriscam75 Electrical 3 02-17-2009 08:15 PM
Ground rod or not? brotherman Electrical 30 07-15-2008 04:58 PM
