Replacing Spliced Knob And Tube - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2011, 01:43 PM   #1
Replacing Spliced Knob and Tube
Just bought a house with crawl space under the floor.
Most of the breakers are now connected to romex but there are still 3 breakers that are connected to the old knob and tube.
It looks like one of those knob and tube lines runs the length of the house and there are aprox. 6 outlets spliced off the knob and tube running up into the walls.
I'm thinking of replacing the knob and tube line with 12g romex and putting each of the outlet splices into a junction box with pig tails.
Any reason not to do this?
fromscratch is offline   Reply With Quote
Old 05-23-2011, 01:57 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Do you mean a junction box in the crawl space and wire running up to the receptacle?
If so, not a problem.
Old 05-23-2011, 02:05 PM   #3
Exactly. Six junction boxes in the crawl space, one for each receptacle.
Old 05-23-2011, 02:23 PM   #4
Rewards Points: 93
Were you intending to leave the knob and tube between the junction boxes and the outlets or were you going to run a new romex cable to each outlet from the new junction boxes?
Perry401 is offline   Reply With Quote
Old 05-23-2011, 02:37 PM   #5
Guessing you are going to tell me I have to replace all the wires coming from the receptacles with new romex wire?
I found that 3 of the receptacles have a romex-type wire (There are two copper wires covered in plastic wrapped in a an outer plastic sheath. The outer plastic sheath is a grey to silver color.) leaving the receptacle and spliced into the knob and tube under the house. I was thinking I could probably just use that wire, However I could probably pull new wire.
I haven't looked at the other room yet. If those receptacles have knob and tube running up the wall and I can't pull new wire, is there a reason not to splice with into the knob and tube wire running up the wall?
Old 05-23-2011, 04:40 PM   #6
Mad Scientist
As long as you don't extend the circuit at all, replacing portions of it with new wiring as you plan to do is fine. I'd make an effort to replace the runs from the receptacles if possible, though.
McSteve is offline   Reply With Quote
Old 05-24-2011, 09:04 AM   #7
I ask the impossible!
Rewards Points: 640
Even better would be if you could pull new romex up to the outlets and have a romex cable going from one outlet to the next and avoid the junction boxes in the crawl space all-together, use your wires that go up to the outlets to pull your new cables through. If the holes through floor and studs are too tight to pull new romex taped to old wire, then tape a string to the old wire, pull that through, then use the string to pull the new cable up.
Junction boxes are an increase in the number of places a loose connection could happen. Also, each junction box means an extra 6" of cable x3. You might not use much more wire, and you'll probably have a little less work in the crawlspace which is usually not that much fun.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 01:17 PM
looking at a house with "some" knob and tube shaner123 Electrical 8 02-08-2011 05:56 PM
ballpark figure for replacing knob and tube wiring GroverBailey Off Topic 5 05-19-2010 12:44 PM
knob and tube question marin001 Electrical 7 12-21-2008 04:49 PM
Cost of replacing old knob ant tube wiring in house bikerboy337 Electrical 3 03-26-2005 09:50 AM
